Problem VPN with Cisco RV180 site to site
abarreau78
I have setup my rv180 in site to site in Ipsec VPN , it's working fine with selecting IP adress as Remote address ( Fixed IP adrress).
When i change setup to FQDN and use a name instead of an IP adress , i get the following  messages in the log.
Fri Oct 18 09:35:32 2013 (GMT +0100): [router57182E] [IKE] INFO:  Adding IPSec configuration with identifier "Spidyone"
Fri Oct 18 09:35:32 2013 (GMT +0100): [router57182E] [IKE] INFO:  Adding IKE configuration with identifier "Spidyone"
Fri Oct 18 09:35:37 2013 (GMT +0100): [router57182E] [IKE] ERROR:  Failed to resolve remote FQDN "my.vpn.name". Backing off resolution for 2 seconds.
Fri Oct 18 09:35:37 2013 (GMT +0100): [router57182E] [IKE] ERROR:  Could not find configuration for 188.x.x.x[500]
"my.vpn.name" and  "188.x.x.x" have been replace for security reason but we check that "my.vpn.name is a good DNS name with DNS server setup in the RV180 configuration. DNS setup in WAN IPV4.
Thank for reply.
lariasqu
Hi, thank you for using our forum, my name is Luis I am part of the Small business Support community. I think could be a compatibility issues with your DDNS provider, the RV180 supports DDNS providers such as DynDNS.com, TZO.com, or 3322.org, anyway I suggest you to contact you DDNS provider to verify the information with them.
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
