Router 888 L3 interface missing
tafa
Hello, I just bought a CISCO 888 router and I am trying to configure it for a very first time. The problem is that I need the L3 port for NAT but the router shows me only the L2 ports (0-3).
20 Replies 20
try under the L2 interface
no switch port <<- this make L2 port as L3 interface
Incomplete command
do you try config IP under the interface if you success then it L3 not L2.
I tried but showed me it is L2
can you share
show IP interface status
Wrong command
Show ip interface breif
so you dont have WAN interface you have BRI
I think you can config IP under the BRI interface
interface bri X
ip address
So the cable go in to SHDSL port? I will configure to receive IP from the ISP. But which BRIE to use?
BRI 0
Still not working:(
https://www.cisco.com/c/en/us/support/docs/wan/point-to-point-protocol-ppp/10308-bri-mppp.html
OK, since it not accept the config then try config dialer interface and use BRI as HW interface.
check the example above
