RV042 V3 and SBS 2003 RWW
Keith Lufkin
I have tried replacing a loaner RV082 V2 with an RV042 V3 router with firmware 4.0.4.02. All worked well, including the site to site VPN. However, in spite of the fact that I have ports 443 and 4125 forwarded to the server (192.168.2.10), we are unable to connect via RWW. There is no such problem with the RV082. What is different with the way we configure these V3 routers for port forwarding? Thanks.
jasbryan
Level 6
Level 6
Keith,
Please log into the RV042 v3 under the firewall make sure you uncheck use HTTPS. This should solve your problem.
Jasbryan.
Thanks for the heads up. I failed to realize HTTPS was defaulted to on with this version.
