rv110w just dies and resurrects plenty of times, not old, help
Arcanebits
Hi, I have a cisco rv110w, it doesnt have 4 years of work, never ever been in a bussy office.
It now, just keep disconecting, i cant even ping it when this happens, and happens A LOT.
Is this the time to get a new device? quite sad about the "premium" quality, maybe a small soho fortinet do?
Thanks for any help!
Last page of log, and im sure the error its happening here.... but no warnings or errors
1 2023-09-04 8:07:17 AM info httpd[410]: Administrator logined from 192.168.1.100
2 2023-09-04 8:07:17 AM info httpd[410]: Administrator session timeout.
3 2023-09-04 8:07:17 AM info udhcpd[694]: sending ACK to 192.168.1.100
4 2023-09-04 8:07:17 AM info udhcpd[694]: received REQUEST from 00:1E:8C:F2:8B:84
5 2023-09-04 8:07:05 AM info syslog: Link Up: Port 4
6 2023-09-04 8:07:01 AM info syslog: Link Down: Port 4
7 2023-09-04 8:06:57 AM info udhcpd[694]: sending ACK to 192.168.1.100
8 2023-09-04 8:06:57 AM info udhcpd[694]: received REQUEST from 00:1E:8C:F2:8B:84
9 2023-09-04 8:06:45 AM info syslog: Link Up: Port 4
10 2023-09-04 8:06:41 AM info syslog: Link Down: Port 4
11 2023-09-04 8:05:51 AM info udhcpd[694]: sending ACK to 192.168.1.100
12 2023-09-04 8:05:51 AM info udhcpd[694]: received REQUEST from 00:1E:8C:F2:8B:84
13 2023-09-04 8:05:39 AM info syslog: Link Up: Port 4
14 2023-09-04 8:05:35 AM info syslog: Link Down: Port 4
Requested just errors and warnings
1 2023-09-04 7:08:44 AM warning lan_interface[0]: ip c0a80101 mask ffffff00
2 2023-09-04 7:08:44 AM warning wan ip be8c3f5e
3 2023-09-04 7:08:28 AM warning vlan2: Setting MAC address to c8 00 84 2b 58 65.
4 2023-09-04 7:08:22 AM warning dnsmasq[522]: failed to access /tmp/resolv.conf: No such file or directory
5 2023-09-04 7:08:22 AM err dnsmasq[522]: failed to load names from /etc/hosts: No such file or directory
6 2023-09-04 7:08:23 AM warning eth1: Broadcom BCM4347 802.11 Wireless Controller 5.100.138.11
7 2023-09-04 7:08:23 AM err SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock3
8 2023-09-04 7:08:23 AM warning Found an ST compatible serial flash with 256 64KB blocks; total size 16MB
9 2023-09-04 7:08:23 AM warning eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.138.11
10 2023-09-04 7:08:23 AM warning et_module_init: passivemode set to 0x1
11 2023-09-04 7:08:23 AM warning ctf: module license 'Proprietary' taints kernel.
12 2023-09-04 7:08:23 AM warning Algorithmics/MIPS FPU Emulator v1.5
13 2023-09-04 7:08:23 AM warning Failed to execute /init
14 2023-09-04 7:08:23 AM warning Warning: unable to open an initial console.
15 2023-09-04 7:08:23 AM warning VFS: Mounted root (squashfs filesystem) readonly.
16 2023-09-04 7:08:22 AM warning ip6_tables: (C) 2000-2006 Netfilter Core Team
17 2023-09-04 7:08:22 AM warning ip_tables: (C) 2000-2006 Netfilter Core Team
18 2023-09-04 7:08:22 AM warning ctnetlink v0.93: registering with nfnetlink.
19 2023-09-04 7:08:22 AM warning nf_conntrack version 0.5.0 (512 buckets, 4096 max)
20 2023-09-04 7:08:21 AM warning Netfilter messages via NETLINK v0.30.
21 2023-09-04 7:08:21 AM warning Actions configured
22 2023-09-04 7:08:21 AM warning u32 classifier
23 2023-09-04 7:08:21 AM err pflash: found no supported devices
24 2023-09-04 7:08:20 AM warning fuse init (API version 7.8)
25 2023-09-04 7:08:20 AM warning Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
26 2023-09-04 7:08:20 AM warning TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
27 2023-09-04 7:08:20 AM warning TCP established hash table entries: 2048 (order: 2, 16384 bytes)
28 2023-09-04 7:08:20 AM warning IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
29 2023-09-04 7:08:20 AM warning PCI: Fixing up bus 0
30 2023-09-04 7:08:20 AM warning PCI: no core
31 2023-09-04 7:08:20 AM warning PCI: no core
32 2023-09-04 7:08:20 AM warning Mount-cache hash table entries: 512
33 2023-09-04 7:08:19 AM warning Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
34 2023-09-04 7:08:19 AM warning Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
35 2023-09-04 7:08:19 AM warning Using 150.000 MHz high precision timer.
36 2023-09-04 7:08:19 AM warning CPU: BCM5357 rev 2 at 300 MHz
37 2023-09-04 7:08:19 AM warning PID hash table entries: 512 (order: 9, 2048 bytes)
38 2023-09-04 7:08:19 AM warning Primary data cache 32kB, 4-way, linesize 32 bytes.
39 2023-09-04 7:08:19 AM warning Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
40 2023-09-04 7:08:19 AM warning Built 1 zonelists. Total pages: 16384
balaji.bandi
what is the Firmware running, have you checked any latest firwarre available to upgrade ?
BB
marce1000
                       >...err SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock3
 The device is experiencing a fatal error on the internal filesystem   being used ; try cold power start and check if that can help ; if not try factory reset as a last resort,
 M.
