RV220W and Vodafone Suresignal (Femtocell)
itcconcepts
Hello
Is anyone successfully using the RV220W and a Suresignal? I cannot get the two working together.
I recently upgraded to an FTTC/VDSL2 serivce and splashed out on the RV220W, unfortunately since then I cannot get my Suresignal to work.
Today I replaced the RV220W with the ISP supplied Netgear N300 router, configured the same PPPoe connection, IP range etc. and the Suresignal worked straight away. Ruling out issues with the new internet service or VDSL modem.
I have opened incoming ports, put the Suresignal in the DMZ, assigned a static DHCP - all as per Vodafone’s troubleshooting guide but nothing helps.
·         8 TCP
·         50 TCP
·         500 UDP
·         4500 UDP
·         123 UDP
Unfortunately the Suresignal does not have any, user visible, controls to help diagnose.
Would anyone be able to offer any further insight?
Thank
John
0 Replies 0
