05-18-2021 10:32 PM
Hello community,
i´ve got 3 Cisco RV320 DUAL WAN VPN Router active at 3 different places.
These Routers are connected via WAN.
Actually we got 1 more business location for which i should buy 1 more router and connect it also via WAN to the other Routers.
Does it work, if I setup the WAN connection between Cisco RV320 DUAL WAN VPN Router and Cisco RV340 DUAL WAN VPN Router?
Thanks in advance.
05-19-2021 01:19 AM
Hi there,
Yes, you can configure and run IPSec site-to-site Tunnel between the RV320 and RV340 routers. Here is the guide for RV340 https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5513-configure-a-site-to-site-virtual-private-network-vpn-connect.html
It is similar to the VPN setup with RV320
Martin
05-25-2021 12:49 AM
Thank you very much, i will order and try it.
