09-03-2019 09:28 AM
Recently I have been unable to login to the WEB GUI on my RV345p router. I can get to the login page, if I enter incorrect credentials, i am given a login error (so it is trying to login). If I enter proper credentials, the gui never loads.
Reading prior posts this may have do with a recent firmware upgrade.
Is there an easy way to downgrade the fw if i can not access the management console?
I am sure I copied the running config to the startup config after the upgrade so a simple reboot will not work.
Thanks for any help
09-03-2019 10:10 AM
09-03-2019 12:07 PM
Thanks, I will try the tftp option mentioned in the release notes. As this appears to be an issue, I have to wonder why are fw upgrades being released which effectively lock you out of the management page?
03-03-2023 01:08 PM
I did a factory reset and can't access it or telnet. Other bad thing is I took over from previous IT guy and he won't tell me where he purchased it. So I have a router that I can not use and is a paper weight.
03-03-2023 01:17 PM
connect to Console Port—The router console port is designed for a serial cable connection to a
terminal or a computer that is running a terminal emulation program.
03-03-2023 01:27 PM
I plugged in the console cable/usb. It's COM4. Picked serial in Putty to COM4 and it's just sits there. It's not connecting.
03-03-2023 01:53 PM
Turn off the router, and post complete boot process you see in console ( AS TEXT - NOT Screenshot)
what LED do you see in front?
04-26-2023 05:11 PM
It won't allow me to upload the file.
04-26-2023 05:14 PM
