BGP Configuration Screen mussing on ASA 5508-X
sawinsabaru
Hi everyone,
I have an ASA 5508-X with ASA 9.12(4) and ASDM 7.9(2).
I needed to configure BGP for a VPN with Azure but in ASDM there is no BGP inside Device Setup / Routing or Inside Monitoring / Routing
I configured and tested BGP using commands and it works well but I'm puzzled about why these screens are not showing in ASDM, they were supposedly added way back in ASA 9.2 and ASDM 7.3 as per the release notes...
I also checked requirements and my ASA is in router mode and BGP should be included in the base license.
Any idea?
In routing tab in asdm there is no bgp?
MHM
Ruben Cocheno
@sawinsabaru
Perhaps a glitch on the current ASDM and the ASA release that you using.Upgrade your ASDM to 7.13(1.101) as per Cisco ASA/ASDM Matrix, and try again.
BGP on the CLI is also an option.
https://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html#id_59423
https://www.cisco.com/c/en/us/td/docs/security/asa/asa912/configuration/general/asa-912-general-config/route-bgp.html#ID-2100-00000c73
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
