Route only traffic from specific WAN IP addresses
CorporateITGuy
Going from a Netgear router that has a GUI that is built in and that I understand and moving to a Cisco router, c897va-k9, that has nothing but CLI that I am almost entirely unfamiliar with. Have gotten some help from the Cisco community but keep running into more problems.
Current problem is trying to figure out how to only apply a nat rule when its coming from specific IP Address(es). I can set up nat rules for “general” purpose:
#ip nat inside source static [local_ip] [public_ip]
or
#ip nat inside source static tcp [local_ip] [port] [public_ip] [port]
But I am not sure how to restrict them to only apply these rules to say 50.50.50.50
Thank you for any and all help!
this should work, as example :  (we need to know full config of your device) - make sure you understand the command before you apply (this is your sole responsible - we suggest only based on information)
ip nat inside source static tcp 192.168.0.200 443 40.40.40.40 443 extendable
access-list 100 permit tcp host 50.50.50.50 any eq 443
access-list 100 permit tcp host 45.45.45.45 any eq 443
access-list 100 deny tcp host any any eq 443
access-list 100 permit ip any any
interface g0/0
ip access-group 100 in
BB
17 Replies 17
balaji.bandi
Are you looking to allow any specific port or address ? example :
ip nat inside source static tcp 192.168.10.1 443 interface Gi0/0 443
int gi0/0
access-list 100 permit tcp host y.y.y.y host x.x.x.x  eq 443
access-list 100 deny tcp any host x.x.x.x  eq 443
 I used 443 port for incoming, you can change based on the requirement, and also change interface of your WAN gi0/0 to your WAN side interface.
BB
I’m not entirely sure as I am still very new at Cisco networking.
But what I am trying to do is this:
2 devices are trying to access my server from 2 different locations, lets call them d1 and d2
d1 WAN: 50.50.50.50
d2 WAN: 45.45.45.45
both devices are trying to access my server that I host, lets call it s1
s1 WAN: 40.40.40.40
s1 LAN: 192.168.0.200
Both devices are trying to access this server via https so port 443
when d1 tries to access s1 via WAN no routing should occur
when d2 tries to access s1 via WAN it should be routed to s1’s LAN IP
Does this make sense?
Would I have to make a default deny for everything inbound and then make permit allowances as needed?
interface g0/0
BB
I won't be able to test this until after hours today at the very earliest, so after I test this I will post again. Thank you for your help.
Sorry the reply has been so long coming, but here’s the update.
I want to accept this as the solution but any time that i try to assign either an outbound or an inbound access-list to my WAN interface ( in this case g8 ) I can no longer access the internet from devices inside the VLAN.
you asked this before, I guess it is not really clear what you mean by 'restrict the rules to'. The static NAT entry I mentioned earlier only translates a specific source address.
Maybe you can explain in simple terms what you want to accomplish...
I want to allow access to my satellite offices and only my satellite offices to my servers based on their IP address
Hello @CorporateITGuy ,
the solution provided by @balaji.bandi  should work you need to apply the extended ACL 100 in direction in (inbound)  to the exit interface of your router gi0/0 or other  ( the interface connecting to the public Internet)
Be aware that depending on the type of internet service that is used at your satellite offices their public IP addresses can change over time or not.
If the satellite offices have static IP addresses the solution is correct and it does not need any change over time.
Hope to help
Giuseppe
I think his reply is correct as well but I am unable to test it because as soon as I assign the access-list to g8 I lose the ability to connect the internet from devices on the VLAN. Do I need another entry into the access-list to continue allowing VLAN devices to get to the web?
post the config for us to understand the issue.
BB
Cisco#show run
Building configuration...
Current configuration : 2504 bytes
! Last configuration change at 22:38:05 UTC Thu Oct 7 2021
version 15.4
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
cts logging verbose
license udi pid C897VA-K9 sn FGL220992H6
username [username] privilege 15 password 0 [password]
controller VDSL 0
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface Ethernet0
 no ip address
 shutdown
interface GigabitEthernet0
 switchport access vlan 10
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 description PrimaryWANDesc_
 ip address [WANip] [netMask]
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan10
 ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
ip route 0.0.0.0 0.0.0.0 [ModemIP]
ip access-list extended testOutbound
 permit 192 any any
ip access-list extended testInbound
 remark testing AGAIN if I understand ACLs
 permit tcp host [BranchWAN] eq [port#] host [HQWAN] eq [port#]
 remark above ip for [computer]
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
So I know for the access-list testInbound to take affect it has to be applied to g8, but when I apply the list it over-writes the access-list 1 which, to my understanding, is allowing traffic out of the VLAN right? I guess I'm just not sure where and how to add that same allowance to my testInbound list, or even my test outbound list. Please ask if there is anything I can clarify.
Again thanks for all the help and advice, I really appreciate it.
any ideas?
I am puzzled about your statement that the new access list overwrites access-list 1. The 2 access lists should be independent of each other.
Let us clear up something. You say "access-list 1 which, to my understanding, is allowing traffic out of the VLAN right?" Actually that is not right. acl 1 is controlling address translation. In a sense you are right that acl 1 is necessary for traffic to get out on g8 but technically it is controlling what traffic gets translated and not controlling what traffic gets in.
There is a flaw in acl testInbound as shown in your config. It would permit specific traffic in. But it does not permit anything else. In Cisco IOS at the bottom of an access list is an implied statement that denies everything. Look again at the suggestion from @balaji.bandi . St starts by permitting specific addresses to access 443. Then it denies anything else to 443. And then (very important) it permits everything else. You need the steps that deny other traffic to your server port and that permits every thing else.
I wonder why your configuration has 2 configured static default routes. I like the second one which points to the modem IP. The first one might work (or perhaps it might not work). But even if it does work it is much less efficient than the second one. When a static route points to the outbound interface but does not specify the next hop it makes the router work harder. I suggest removing the first static default route and keep the second one as the only static default route.
Rick
Thank you for taking the time to explain everything for me.
Does access-list 1 affect anything when it hasn't been applied to any interface?
I am aware of the implied deny all that comes at the end of the access list, and for inbound traffic that is what I want for the moment. At this point my problem isn't traffic I want getting in not being able to get in, its traffic can't get out of my network after I apply any access list. Whether inbound or outbound. Maybe the change to the static route will affect that? Not sure but seems like its worth a shot
I tried removing the ip route as you suggested and it seems to have helped a lot thank you!
Again thank you for taking the time to help me
