Hello All, Recently I got an opportunity to perform POC with Cisco ISE (2.7 Patch 4) and Aruba Wireless AP (IAP) to perform 802.1x EAP-FAST (machine + user) authentication followed by Posture Assessment on Windows 10 Machines (installed with AnyConnect 4.9 NAM , Posture and compatible compliance module) I was able to perform all the requirements of client successfully. Most challenging part of to achieve seamless posture assessment using dynamic URL redirect. Attaching the document which can guide everyone to configure the same. Hope it helps. Regards, Mitesh Manwatkar
Lalit.Teotia
Hi @Mitesh Manwatkar
Thank you for sharing the guides.
Would you mind attaching Aruba side configs like Wi-Fi SSID and Aruba Role configs?
Have you defined ISE PSN FQDN in the "Call Home" list?
I have tried the suggested configs but facing issue with ISE PSN discovery.
URL redirect to ISE CPP portal is working but Cisco Anyconnect Agent could not detect ISE PSN and it stays at "No Policy Server" detected.
If i copy ConnectionData.xml file at C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\ISE Posture\ path then Cisco Anyconnect Client Discovers ISE and Posture is successful.
