Tim Glen
Table of Contents
Summary
In this configuration guide we will take the full chain of certificates and the private key from Let's Encrypt and install it onto our Cisco ASA for Remote Access VPN usage.
You must have a working RA VPN configured on an ASA in order to use this guide. This guide will only help you assign a Let's Encrypt certificate to a working RA VPN. We will not go over how to configure RA VPN on ASA.
Obtain the Certificate from Let's Encrypt
Please take a look at this document. This explains how to use Let's Encrypt to obtain a certificate.
Using Let's Encrypt
Convert to PKCS#12 File
Let's Encrypt provides a Private Key and a full chain of certificates. We will use OpenSSL to convert the certificates and private key into a PKCS#12 file. PKCS12 is a standardized format for creating a 'container' file that will include certificates and a private key. This is a fairly simple process and the command parameters will be explained below.
NOTE: Im using the backslash so that a single command spans multiple lines.  This cool linux feature increases readability and allows us to look at the parameters easily.
openssl pkcs12 -export \
-passout pass:cisco123 \
-in fullchain.pem \
-inkey privkey.pem \
-out asa-ravpn.timslab.fun.p12
openssl - the executable
pkcs12 - the OpenSSL module that will be used
-export - This option specifies that a PKCS#12 file will be created rather than parsed.
-passout - Pass phrase source to encrypt any outputted private keys with. passout can accept several types of input for the password so we use pass: to prefix the real password. See the Pass Phrase Options section in this document for specifics.
-in - The filename to read certificates from.
-inkey - The filename to read private keys from.
-out -This specifies filename to write the PKCS#12 file to. This will be a binary file.
Convert Binary to Base64 Format
The ASA supports PKCS#12 in Base64 format but NOT in binary, so with one easy command, we will convert the binary file to Base64.
openssl base64 -in asa-ravpn.timslab.fun.p12 -out asa-ravpn.timslab.fun.b64
base64 - the OpenSSL module that will be used
-in - The filename to read the PKCS#12 file from.
-out - The filename to write the Base64 file to
Short Digression
I've seen a lot of PEM based certificate and key files and this output file looks similar but is missing the headers I've always seen.  Is this file a PEM file?
The output file is an Base64 encoded ASCII. The output file is not binary.
A PEM file is Base64 encoded and may look similar to the output file.
PEM files are not required to have a Header and Footer.  The output files do not have a Header and Footer.
The output file may be called a PEM file.
Import the PKCS#12 File
Use this command to import the text based PKCS#12 file and create trustpoints. Be sure to note that when we created the PKCS#12 from the Let's Encrypt data we used the password cisco123 to encrypt the data. Be sure to use the proper password or the import will fail.
crypto ca import asa-ravpn pkcs12 cisco123
Assign the Trustpoint to the SSL Interface
Now we will assign the newly created Trustpoint to the Outside Interface.
In my lab the WebVPN is configured to use the Outside Interface, in your environment be sure to configure the proper interface.
ssl trust-point asa-ravpn Outside
Verify
Check the certificates in the ASA trustpoint
show crypto ca certificates asa-ravpn
Use OpenSSL to interrogate the certificate exposed to the Internet
openssl s_client -showcerts asa-ravpn.timslab.fun:443
Use AnyConnect to connect to the RA VPN
Renewal
Let's Encrypt issues certificate with a lifetime of 90 days. Typically I like to renew my Let's Encrypt certificate at 75 days.
Let's Encrypt and Certbot are not specifically built for RA VPN so renewal is a manual process, just start here and you will have a new cert and have it installed in less than 15 minutes.
Automation
Shortly I will begin working on code to automate this process and will post the Github link here.
That's it!    Please let me know how this guide works out and if you have any questions.
adamgerber
Good write-up, looking forward to the automation portion.
RevSupport
Any progress on providing steps to automate this process?
