Dan Lukes
This document enumerates all those XML tags added/removed/changed between various firmware versions.
It is based on spacfg.xml saved from SPA504G phone with factory-default configuration.
MAC addresses, serial numbers and IP adresses has been removed from file.
[toc maxlevel=1;]
7.3.7 -> 7.4.3
Added tags
  1. <Default_Character_Encoding group="Regional/Miscellaneous">ISO-8859-1</Default_Character_Encoding>
  2. <BLF_DNS_Enable group="Attendant_Console/General">No</BLF_DNS_Enable>
Changed defaults
    • <Secure_Call_Indication_Tone group="Regional/Call_Progress_Tones">397@-19,507@-19;3(0/2/0,.2/.1/1,.1/2.1/2)</Secure_Call_Indication_Tone>
    • <Secure_Call_Indication_Tone group="Regional/Call_Progress_Tones">397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)</Secure_Call_Indication_Tone>
    • <Select_Logo group="Phone/General">Default</Select_Logo>
    • <Select_Logo group="Phone/General"/>
Other changes
    • <Host_Name group="Info/System_Information">SipuraSPA</Host_Name>
    • <Host_Name group="Info/System_Information">SEP----MAC-----</Host_Name>
Note the 7.3.7 spacfg.xml file contain configuration for all Ext_1 ... Ext_12 regardless of number of extensions supported on particular device. Newer version contain only those Ext_N sections valid for device in question.
7.4.3 -> 7.4.4
Added tags
  1. <SCA_Sticky_Auto_Line_Seize group="Phone/Miscellaneous_Line_Key_Settings">No</SCA_Sticky_Auto_Line_Seize>
  2. <Restrict_MWI_N_ group="Ext_N/Share_Line_Appearance">No</Restrict_MWI_N_>
  3. <Voice_Mail_Subscribe_Interval_N_ group="Ext_N/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_N_>
  4. <User_ID_with_Domain_N_ group="Ext_N/Call_Feature_Settings">No</User_ID_with_Domain_N_>
Changed defaults
    • <Idle_Key_List group="Phone/Programmable_Softkeys">em_login|1;acd_login|1;acd_logout|1;redial|5;resume|5;dir|6;avail|6;unavail|6;cfwd|7;chkcfwd|7;dnd|8;chkdnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout</Idle_Key_List>
    • <Idle_Key_List group="Phone/Programmable_Softkeys">em_login|1;acd_login|1;acd_logout|1;avail|3;unavail|3;redial|5;resume|5;dir|6;cfwd|7;chkcfwd|7;dnd|8;chkdnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout</Idle_Key_List>
Other changes
    • <LCD_Contrast group="User/Audio_Volume">8</LCD_Contrast>
    • <LCD_Contrast group="User/LCD">8</LCD_Contrast>
    • <Back_Light_Timer group="User/Audio_Volume">10 s</Back_Light_Timer>
    • <Back_Light_Timer group="User/LCD">10 s</Back_Light_Timer>
7.4.4 -> 7.4.6
Added tags
  1. <Phone-UI-readonly group="System/System_Configuration">No</Phone-UI-readonly>
  2. <DNS_Query_TTL_Ignore group="System/Optional_Network_Configuration">No</DNS_Query_TTL_Ignore>
  3. <Dialog_SDP_Enable group="SIP/SIP_Parameters">No</Dialog_SDP_Enable>
  4. <Ignore_DHCP_Time_Offset group="Regional/Miscellaneous">Yes</Ignore_DHCP_Time_Offset>
  5. <Line_Navigation group="Phone/Miscellaneous_Line_Key_Settings">Per Line</Line_Navigation>
  6. <Programmable_Softkey_Enable group="Phone/Programmable_Softkeys">No</Programmable_Softkey_Enable>
  7. <Progressing_Key_List group="Phone/Programmable_Softkeys">endcall|2</Progressing_Key_List>
  8. <Releasing_Key_List group="Phone/Programmable_Softkeys">endcall|2;</Releasing_Key_List>
  9. <Hold_Key_List group="Phone/Programmable_Softkeys">resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd</Hold_Key_List>
  10. <Shared_Active_Key_List group="Phone/Programmable_Softkeys">newcall|1;barge|2;cfwd|3;dnd|4</Shared_Active_Key_List>
  11. <Shared_Held_Key_List group="Phone/Programmable_Softkeys">resume|1;barge|2;cfwd|3;dnd|4</Shared_Held_Key_List>
  12. <Voice_Quality_Report_Address_N_ group="Ext_N/SIP_Settings"/>
  13. <Deep_Bass group="User/Audio_Volume">Default</Deep_Bass>
Renamed tags (meaning changed slightly as well)
    • <SCA_Line_ID_Mapping group="Phone/Miscellaneous_Line_Key_Settings">Vertical First</SCA_Line_ID_Mapping>
    • <Line_ID_Mapping group="Phone/Miscellaneous_Line_Key_Settings">Vertical First</Line_ID_Mapping>
Removed tags
  1. <BLF_DNS_Enable group="Attendant_Console/General">No</BLF_DNS_Enable>
Changed defaults
    • <Idle_Key_List group="Phone/Programmable_Softkeys">em_login|1;acd_login|1;acd_logout|1;avail|3;unavail|3;redial|5;dir|6;cfwd|7;dnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout</Idle_Key_List>
    • <Connected_Key_List group="Phone/Programmable_Softkeys">confLx|1;flash|1;xferLx|2;conf|3;xfer|4;toggle|4;redial|5;dir|6;bxfer|7;park|8;phold</Connected_Key_List>
    • <Connected_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;conf|3;xfer|4;toggle;bxfer;confLx;xferLx;park;phold;flash;</Connected_Key_List>
    • <Start-Xfer_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;xfer|4;callCancel</Start-Xfer_Key_List>
    • <Start-Xfer_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;xfer|4</Start-Xfer_Key_List>
    • <Start-Conf_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;conf|3;callCancel</Start-Conf_Key_List>
    •  <Start-Conf_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;conf|3;</Start-Conf_Key_List>
    • <Conferencing_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;join|3</Conferencing_Key_List>
    • <Conferencing_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;join|4</Conferencing_Key_List>
Other changes
    • <Application_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <Application_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <Serv_Subscribe_Failed_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <Serv_Subscribe_Failed_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <Serv_Subscribing_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <Serv_Subscribing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <SNRM_Day_Mode_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <SNRM_Day_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <SNRM_Night_Mode_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <SNRM_Night_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <Parking_Lot_Idle_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <Parking_Lot_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <Parking_Lot_Busy_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <Parking_Lot_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <BLF_Idle_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <BLF_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <BLF_Ringing_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <BLF_Ringing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <BLF_Busy_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <BLF_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
    • <BLF_Held_LED group="Attendant_Console/Attendant_Console_Key_LED_Pattern"/>
    • <BLF_Held_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
7.4.6 -> 7.4.7
Added tags
  1. <Phone-UI-user-mode group="System/System_Configuration">No</Phone-UI-user-mode>
  2. <Layer_2_Logging group="System/Optional_Network_Configuration">No</Layer_2_Logging>
  3. <Enable_LLDP-MED group="System/VLAN_Settings">Yes</Enable_LLDP-MED>
  4. <Network_Startup_Delay group="System/VLAN_Settings">3</Network_Startup_Delay>
  5. <Resync_At__HHmm_ group="Provisioning/Configuration_Profile"/>
  6. <Use_Remote_Pref_Codec_N_ group="Ext_N/Audio_Configuration">No</Use_Remote_Pref_Codec_N_>
  7. <Codec_Negotiation_N_ group="Ext_N/Audio_Configuration">Default</Codec_Negotiation_N_>
  8. <Miss_Call_Banner group="User/Supplementary_Services">Yes</Miss_Call_Banner>
Changed defaults
    •  <Reorder_Delay group="Regional/Control_Timer_Values__sec_">5</Reorder_Delay>
    • <Reorder_Delay group="Regional/Control_Timer_Values__sec_">255</Reorder_Delay>
    • <Dialing_Input_Key_List group="Phone/Programmable_Softkeys">dial|1;delchar|2;clear|3;cancel|4;left|5;right|6;starcode|7;alpha|8</Dialing_Input_Key_List>
    • <Dialing_Input_Key_List group="Phone/Programmable_Softkeys">dial|1;delchar|2;clear|3;cancel|4;left|5;right|6;starcode|7;alpha|8;dir</Dialing_Input_Key_List>
Other changes
    • <Operational_VLAN_ID group="Info/Phone_Status">n/a</Operational_VLAN_ID>
    • <Operational_VLAN_ID group="Info/Phone_Status">0</Operational_VLAN_ID>
7.4.7 -> 7.4.8a
Added tags
  1. <PoE_Power_Required group="System/Power_Setting">Normal</PoE_Power_Required>
  2. <Call_Appearance_Per_Line group="Phone/Miscellaneous_Line_Key_Settings">2</Call_Appearance_Per_Line>
  3. <Auto_Ans_Page_On_Active_Call_N_ group="Ext_N/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_N_>
Changed defaults
    • <Start-Xfer_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;xfer|4;toggle;</Start-Xfer_Key_List>
    • <Start-Conf_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;conf|3;toggle;</Start-Conf_Key_List>
7.4.8a -> 7.4.9a
Added tags
  1. <Asset_ID group="System/Inventory_Settings"/>
  2. <Keep_Referee_When_REFER_Failed group="SIP/SIP_Parameters">No</Keep_Referee_When_REFER_Failed>
  3. <Display_Diversion_Info group="SIP/SIP_Parameters">No</Display_Diversion_Info>
  4. <Resync_At_Random_Delay group="Provisioning/Configuration_Profile">600</Resync_At_Random_Delay>
  5. <Call_Pickup_Tone group="Regional/Call_Progress_Tones">440@-10;30(.3/9.7/1)</Call_Pickup_Tone>
  6. <Ring11 group="Phone/Ring_Tone">n=Pulse;w=5;c=1</Ring11>
  7. <Ring12 group="Phone/Ring_Tone">n=Du-dut;w=6;c=1</Ring12>
  8. <Broadsoft_ACD_N_ group="Ext_N/Call_Feature_Settings">No</Broadsoft_ACD_N_>
  9. <Feature_Key_Sync_N_ group="Ext_N/Call_Feature_Settings">No</Feature_Key_Sync_N_>
  10. <Alternate_Proxy_N_ group="Ext_N/Proxy_and_Registration"/>
  11. <Alternate_Outbound_Proxy_N_ group="Ext_N/Proxy_and_Registration"/>
  12. <Dual_Registration_N_ group="Ext_N/Proxy_and_Registration">No</Dual_Registration_N_>
  13. <Reversed_Auth_Realm_N_ group="Ext_N/Subscriber_Information"/>
  14. <Handset_Version group="User/Audio_Volume">Auto</Handset_Version>
  15. <Call_Pickup_Audio_Notification group="Attendant_Console/General">No</Call_Pickup_Audio_Notification>
Removed tags
  1. <Call_Feature_Sync_Ext group="Phone/Broadsoft_Settings">Disabled</Call_Feature_Sync_Ext>
Changed defaults
    • <Idle_Key_List group="Phone/Programmable_Softkeys">em_login|1;acd_login|1;acd_logout|1;astate|2;avail|3;unavail|3;redial|5;dir|6;cfwd|7;dnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout</Idle_Key_List>
Other changes
    • <Operational_VLAN_ID group="Info/Phone_Status">N/A</Operational_VLAN_ID>
7.4.9a -> 7.4.9c
No changes
7.4.9c -> 7.5.1a
Added tags
  1. <NTP_Enable group="System/Optional_Network_Configuration">Yes</NTP_Enable>
  2. <Auto_Ans_GrPage_On_Active_Call group="SIP/Linksys_Key_System_Parameters">Yes</Auto_Ans_GrPage_On_Active_Call>
  3. <Custom_CA_RULE group="Provisioning/CA_Settings"/>
  4. <Locale group="Regional/Miscellaneous">en-US</Locale>
  5. <Softkey_Navigation_Style group="Phone/Miscellaneous_Line_Key_Settings">Scrollable</Softkey_Navigation_Style>
  6. <XML_User_Name group="Phone/XML_Service"/>
  7. <XML_Password group="Phone/XML_Service"/>
  8. <PSK_7 group="Phone/Programmable_Softkeys"/>
  9. <PSK_8 group="Phone/Programmable_Softkeys"/>
  10. <PSK_9 group="Phone/Programmable_Softkeys"/>
  11. <PSK_10 group="Phone/Programmable_Softkeys"/>
  12. <PSK_11 group="Phone/Programmable_Softkeys"/>
  13. <PSK_12 group="Phone/Programmable_Softkeys"/>
  14. <PSK_13 group="Phone/Programmable_Softkeys"/>
  15. <PSK_14 group="Phone/Programmable_Softkeys"/>
  16. <PSK_15 group="Phone/Programmable_Softkeys"/>
  17. <PSK_16 group="Phone/Programmable_Softkeys"/>
  18. <User_Equal_Phone_N_ group="Ext_N/SIP_Settings">No</User_Equal_Phone_N_>
  19. <Call_Park_Monitor_Enable_N_ group="Ext_N/Call_Feature_Settings">No</Call_Park_Monitor_Enable_N_>
  20. <Resident_Online_Number_N_ group="Ext_N/Subscriber_Information"/>
  21. <SIP_URI_N_ group="Ext_N/Subscriber_Information"/>
  22. <DTMF_AVT_Packet_Interval_N_ group="Ext_N/Audio_Configuration">0</DTMF_AVT_Packet_Interval_N_>
  23. <Cfwd_Setting group="User/Call_Forward">Yes</Cfwd_Setting>
  24. <Shared_Line_DND_Cfwd_Enable group="User/Supplementary_Services">Yes</Shared_Line_DND_Cfwd_Enable>
  25. <Attendant_Console_Call_Park_Code group="Attendant_Console/General">*68</Attendant_Console_Call_Park_Code>
  26. <Attendant_Console_Call_unPark_Code group="Attendant_Console/General">*88</Attendant_Console_Call_unPark_Code>
Changed defaults
    • <DHCP_Option_To_Use group="Provisioning/Configuration_Profile">66,160,159,150</DHCP_Option_To_Use>
    • <DHCP_Option_To_Use group="Provisioning/Configuration_Profile">66,160,159,150,60,43,125</DHCP_Option_To_Use>
Other changes
    • <Call_State group="Info/Line_L_Call_C_Status">Disabled</Call_State>
    • <Call_State group="Info/Line_L_Call_C_Status"/>
    • <Tone group="Info/Line_L_Call_C_Status">None</Tone>
    • <Tone group="Info/Line_L_Call_C_Status"/>
  1. <Custom_CA_Provisioing_Status group="Info/Custom_CA_Status"/>
  2. <Custom_CA_Info group="Info/Custom_CA_Status">Not Installed</Custom_CA_Info>
    • <Ringer_Volume group="User/Audio_Volume">8</Ringer_Volume>
    • <Ringer_Volume group="User/Audio">8</Ringer_Volume>
    • <Speaker_Volume group="User/Audio_Volume">8</Speaker_Volume>
    • <Speaker_Volume group="User/Audio">8</Speaker_Volume>
    • <Handset_Volume group="User/Audio_Volume">10</Handset_Volume>
    • <Handset_Volume group="User/Audio">10</Handset_Volume>
    • <Headset_Volume group="User/Audio_Volume">10</Headset_Volume>
    • <Headset_Volume group="User/Audio">10</Headset_Volume>
    • <Handset_Version group="User/Audio_Volume">Auto</Handset_Version>
    • <Handset_Version group="User/Audio">Auto</Handset_Version>
    • <Deep_Bass group="User/Audio_Volume">Default</Deep_Bass>
    • <Deep_Bass group="User/Audio">Default</Deep_Bass>
7.5.1a -> 7.5.2b
Added tags
  1. <Redirect_Keep_Alive group="SIP/NAT_Support_Parameters">No</Redirect_Keep_Alive>
  2. <CISCO_XML_EXE_Auth_Mode group="Phone/XML_Service">Trusted</CISCO_XML_EXE_Auth_Mode>
  3. <Speakerphone_Enable group="User/Audio">Yes</Speakerphone_Enable>
  4. <Attendant_Console_Font_Size group="Attendant_Console/General">10</Attendant_Console_Font_Size>
  5. <Attendant_Console_LCD_Contrast group="Attendant_Console/General">7</Attendant_Console_LCD_Contrast>
7.5.2b -> 7.5.3
Added tags
  1. <Escape_Special_Character group="SIP/SIP_Parameters">Yes</Escape_Special_Character>
  2. <HTTP_Report_Method group="Provisioning/Configuration_Profile">POST</HTTP_Report_Method>
Changed defaults
    • <Attendant_Console_LCD_Contrast group="Attendant_Console/General">7</Attendant_Console_LCD_Contrast>
    • <Attendant_Console_LCD_Contrast group="Attendant_Console/General">12</Attendant_Console_LCD_Contrast>
7.5.3 -> 7.5.4
Added tags
  1. <Use_Backup_IP group="System/Internet_Connection_Type_">Yes</Use_Backup_IP>
  2. <Display_Anonymous_From_Header group="SIP/SIP_Parameters">No</Display_Anonymous_From_Header>
  3. <G711u_Enable_N_ group="Ext_N/Audio_Configuration">Yes</G711u_Enable_N_>
  4. <G711a_Enable_N_ group="Ext_N/Audio_Configuration">Yes</G711a_Enable_N_>
  5. <BXfer_To_Starcode_Enable group="Attendant_Console/General">No</BXfer_To_Starcode_Enable>
  6. <BXfer_On_Speed_Dial_Enable group="Attendant_Console/General">Yes</BXfer_On_Speed_Dial_Enable>
7.5.4 -> 7.5.5
Added tags
  1. <Show_DTMF_Digits_When_Connected group="Regional/Miscellaneous">No</Show_DTMF_Digits_When_Connected>
  2. <Silent_Ring_Duration group="Phone/Ring_Tone">60</Silent_Ring_Duration>
  3. <SCA_Unseize_Delay_N_ group="Ext_N/Share_Line_Appearance">0</SCA_Unseize_Delay_N_>
  4. <Use_Line_Keys_For_BLF_List group="Attendant_Console/General">No</Use_Line_Keys_For_BLF_List>
  5. <BLF_Label_Display_Mode group="Attendant_Console/General">Name</BLF_Label_Display_Mode>
Other changes
    • <Custom_CA_Provisioing_Status group="Info/Custom_CA_Status"/>
    • <Custom_CA_Provisioning_Status group="Info/Custom_CA_Status"/>
7.5.5 -> 7.5.6
Added tags
  1. <Enable_Broadsoft_Hoteling_N_ group="Ext_N/Call_Feature_Settings">No</Enable_Broadsoft_Hoteling_N_>
  2. <Hoteling_Subscription_Expires_N_ group="Ext_N/Call_Feature_Settings">3600</Hoteling_Subscription_Expires_N_>
  3. <Auto_Register_When_Failover_N_ group="Ext_N/Proxy_and_Registration">No</Auto_Register_When_Failover_N_>
  4. <Rx_Payload_In_18x_Media_Session_N_ group="Ext_N/Audio_Configuration">Use Local SDP</Rx_Payload_In_18x_Media_Session_N_>
Other changes
    • <Client_Certificate group="Info/Product_Information">Installed</Client_Certificate>
    • <Client_Certificate group="Info/Product_Information">Installed (1024 bits)</Client_Certificate>
  1. <Hoteling_State group="Info/Ext_1_Status">Disabled</Hoteling_State>
7.5.6 -> 7.5.7
Added tags
  1. <Enable_SSLv3 group="System/Optional_Network_Configuration">No</Enable_SSLv3>
7.5.7 -> 7.5.7s
Added tags
  1. <CISCO_XML_EXE_Enable group="Phone/XML_Service">No</CISCO_XML_EXE_Enable>
Changed defaults
    • <CISCO_XML_EXE_Auth_Mode group="Phone/XML_Service">Trusted</CISCO_XML_EXE_Auth_Mode>
    • <CISCO_XML_EXE_Auth_Mode group="Phone/XML_Service">Local Credential</CISCO_XML_EXE_Auth_Mode>
7.5.7s -> 7.6.0
No changes
7.6.0 -> 7.6.1
Added tags
  1. <Sip_Accept_Encoding group="SIP/SIP_Parameters">none</Sip_Accept_Encoding>
7.6.1 -> 7.6.2
Added tags
  1. <User_Web_Password group="System/System_Configuration"/>
  2. <Disable_Local_Name_To_Header group="SIP/SIP_Parameters">No</Disable_Local_Name_To_Header>
  3. <DND_Cfwd_Active_Warning group="User/Supplementary_Services">No</DND_Cfwd_Active_Warning>
  4. <Mute_Enable group="User/Audio">Yes</Mute_Enable>
7.6.2 -> 7.6.2a
Added tags
  1. <Enable_Direct_Action_Url group="System/System_Configuration">Yes</Enable_Direct_Action_Url>
  2. <Caller_ID_Display_Length group="SIP/SIP_Parameters">long</Caller_ID_Display_Length>
Removed tags
  1. <DND_Cfwd_Active_Warning group="User/Supplementary_Services">No</DND_Cfwd_Active_Warning>
7.6.2a -> 7.6.2b
Added tags
  1. <SSL_Key_Negotiation group="System/Optional_Network_Configuration">RSA</SSL_Key_Negotiation>
Dan Miley
Level 3
Level 3
Thanks for doing this Dan That is a good piece of work.
I'll refer folks to this when they are asking why does my provisioning file created with 7.4.8 cause problems with a phone running 7.5.6
Dan
Dan Lukes
good piece of work
Thanks, nice to hear. May be someone will rate it ;-)
why ... file created with 7.4.8 cause problems with ... 7.5.6
Provisioning file created for older firmware should not cause issues on newer firmware. Default values of added tags are "reasonable" most of time and deleted tags are causing no problem as they are silently ignored.
Of course, I assume no one is allowed to reconfigure phone using either WWW UI or embedded menu. In such case old-stile provisioning file may not revert those manual changes.
