smallbusiness
Community Manager
Community Manager
Article ID:5260
Get to Know the SG350-28P 28-Port Gigabit PoE Managed Switch
Objective
The Cisco SG350-28P 28-Port Gigabit Power over Ethernet (PoE)Managed Switch is a standalone switch that provides 24/28 ports of Gigabit Ethernet and 4/28 (2 SFP + 2 Combo) Gigabit Ethernet ports. It comes with a new generation, highly-integrated packet processor for Carrier Ethernet and Small-Medium Enterprise (SME) applications with full wire-speed performance.
This article aims to show the features of the SG350-28P 28-Port Gigabit PoE Managed Switch.
Applicable Devices
  • SG350-28P
Software Version
  • 2.1.0.63
SG350-28P Features
Product Features
  • Link Flap Prevention
  • Support auto detect 100M or 1000M Small Form-Factor Pluggable (SFP) modules and auto configure the correct speed.
    • The speed of the SFP ports can be manually configured
  • USB port that allows the following:
    • Backing up of configuration files
    • Loading of new image or configuration files
  • Quality of Service (QoS)
Egress policy
    • Egress ACL
    • 2 Rate 3 Colors (2R3C)
  • Port Monitor/ Switched Port Analyzer (SPAN)
    • 7-session SPAN
    • Policy-based Flow Mirroring
  • Switch Management
  • Command Line Interface (CLI) Output modifier
  • Bonjour IPv6 Support
  • Web-based utility
    • Search
    • Wizards: Access Control List (ACL)
    • Save icon
    • Syslog Popup
    • Show tech-support
  • Traffic Monitoring
- Counters History/Counters Graph
- SFLOW v5
  • Packet Processor - AlleyCat3: 98DX3235 (GE), 98DX1235 (FE)
  • Embedded CPU - Marvell MSIS /400Mhz
  • PHY-
    • 88E1680 - Integrated Octal 10/100/1000 Mbps Energy Efficient Ethernet Transceiver
    • 88E3680 - Integrated Octal 10/100 Mbps Energy Efficient Ethernet Transceiver
    • 88E1543 - Combo port support
  • DRAM - 512 MB (DDR3)
  • Flash - 256 MB NAND Flash
  • Protocol Based Virtual Local Area Network (VLAN)
  • IP Subnet Based VLAN
  • Logging aggregation disabled by default
Ports
  • Power over Ethernet (PoE) Support
  • 60W PoE
  • PoE Link Layer Discovery Protocol (LLDP), Cisco Discovery Protocol (CDP) support (power negotiation)
  • PD port support (PD70224 + PD70211)
  • New PoE chipset allows devices to function as power client and request specific power consumption
  • PoE controller embedded in Network ASIC (AC3) allows faster communication speed between the Network-ASIC and the PoE-chip
  • 4-port AF/AT (Ports 1-2, 13-14)
  • two Combo ports that consist of one RJ45 interface and one Mini-GBIC (SFP) interface
  • Rest of the ports is Power Sourcing Equipment (PSE): AF/AT.
  • PSE Port support: 24 ports
  • Up to 12 simultaneous ports with full 15.4 support
  • Console/Terminal Port (RJ45) for device management and debug
  • asynchronous data of eight data bits
  • one-stop bit
  • no parity
  • Default Baud rate of 115200 bps51H4FP1E51H4FP1E
  • USB 2.0 port support
  • FAT32 for Read/Write
  • NTFS for Read-only
Buttons
  • Reset button
LED Indication
Ports
Function
LED Names
LED Behavior
LED Reference
System
System
(Dual colors LED)
System
GREEN
  • Off - System OFF
  • Solid Green - System is On and Ready
  • Blinking Green - Booting/System Self-Test or acquiring IP address
AMBER
  • Blinking Amber - detect HW failed.
RJ45 Ports
Link/Act and PoE
Left LED
LINK/ACT
GREEN
  • OFF - No Link is detected
  • ON - Link is detected
  • Blinking Green - Rx/Tx Data
Right LED
PoE
AMBER
  • OFF - No PD detected
  • Solid Amber - 802.3 af/at PD is detected
  • Blinking Amber - Negotiation
Combo Ports
Link/Act and Speed
SFP ports share with RJ45
Left LED
LINK/ACT
GREEN
  • Blinking Green - Rx/TX Data
Right LED Speed
GREEN
  • OFF - 10M/100M Link is Detected or No Link
  • Solid Green - 1000M link is Detected
SFP ports
Dedicated Mini-GBIC Port
Left LED
LINK/ACT
GREEN
Right LED
LINK/ACT
GREEN
rashidrahman911
I have a cisco switch (SG350 CIsco), in the problem is when I configure management VLAN and set the IP address this switch is not working.
follow this  command
1st time create vlan
than
interface vlan 50
ip address 192.168.1.21 255.255.255.0
exit
devise are not working
