Alberto Montilla
SPA Ringtone Utility. Convert and load your ringtone from a wav (PCM G711) file into the phone.
redbug2675
Community Member
Do you have linux (or windows command line) version of this software. I would like to add ringtone uploader in our intranet.
Patrick Born
Hi redbug2675,
This utility is only available as a Windows utility. It runs a small GUI which requests the IP address of the phone so no command line version either.
Patrick
kevIN75010
This utility works and is simple but when I download a music I can listening only 5 or 6 seconds of music on my SPA942 or just before upload to my phone when I click Preview it's the same.
This my source format with "ringtone utility": 16-bit PCM, stereo, 44100 samples/s, 148031ms
How can I load a music of something like 30 seconds or 20 seconds?
By the way sorry for my poor english
Kevin
Brent Conway
I downloaded the ringtone.zip and can't open.  Error saying it's 'invalid or corrupted'.
Brent
Jesse.Gibson
Community Member
When I enter the IP address and hit connect I see a bar go across the screen and then the program closes.
Any ideas?
Windows 7 x64
SPA504g - Software Version: 7.4.8a
If you have asterisk pbx installed it can convert any file format it understand to ring tone format which is g726-32.
Using the cli it's done by file convert PATHTOORGINALFILE.wav PATHTODESTFILE.g726-32
Worked for me
