10-04-2018 07:50 AM
I am trying to install a test collector with CSPC 2.3 in order to test upgrade procedure prior to attempting this on the customer collector.
Is this version available for download from Cisco? it appears the earliest version I can retrieve from the download centre is 2.7
Chris
Solved! Go to Solution.
10-08-2018 02:57 AM
10-04-2018 08:23 AM
Hi Chris,
Since CSPC 2.3 is no longer supported, the software is not available for download. Please also note that we have announced release of CSPC 2.8 for October 12th. You may want to consider a fresh install of that for the most up to date security and device support.
Cheers,
Cheri
10-08-2018 02:57 AM
05-28-2019 08:53 AM
Could you share where you were able to find version 2.3? I have not had any luck.
05-28-2019 09:32 AM
There is not upgrade patch from 2.3 therefore it would require a new deployment with new ova to 2.8.x.x. even if you had 2.3.8 patched which could have a possible patch. upgrading to 2.3.8 to 2.8.1.2 would require many hours and possible points of failure it would be be to deploy a new image which we hope will be available soon with a new image on cisco.com
05-29-2019 06:44 AM
Hi, I managed to get this off a colleague who has since left the company, unfortunately I don't have a copy. I only installed this in order to brush up on the layout in order to assist our customers with the exporting of data from the old collector to a new deployment.
I would not recommend installing this version as so much has changed since this version.
Chris
