06-16-2016 01:53 PM
Has anyone been successful at figuring out how to put an SSL certificate on a SNTC collector?
thanks
Solved! Go to Solution.
10-05-2017 08:10 AM
Hi Francisco,
Instructions detailing uploading valid SSL certificate are available in Appendix G in the current CSPC User Guide, beginning on page 293.
Please let us know if you need further assistance. If not, please mark this reply as correct to close the coversation.
Cheers,
Cheri
06-28-2016 06:37 AM
Do you mean, how to apply the entitlement file for uploads, or an SSL certificate for internal access to the collector GUI?
06-28-2016 07:33 AM
Hello Lynden, yes to the second part, I want to import an SSL certificate for internal web access to the SNTC collector. I cant seem to find documentation for this process.
10-04-2017 05:09 PM
Hi, did you were able to import the ssl certificate for internal web access, i have the same scenario, and cant´find any doc either.
thanks in advance
10-05-2017 08:10 AM
Hi Francisco,
Cheers,
Cheri
10-22-2017 09:44 AM
