2960S Express Setup
TCSSpecialist
I have a refurbished 2960S (48 port) that doesn't want to enter Express Setup mode.
I have followed the steps in the user manual for POST, then doing a reset by holding the mode button for 3+7 seconds, and then it seems to properly reset and go through POST again. I can then connect an ethernet cable to the management port and, using a web browser connect to 10.0.0.1 as directed in the manual. I can do this using both Chrome and IE with similar results. I then get the following in my browser:
If I now click on Telnet I am prompted to open a Telnet session but get nothing after that.
If I click on Web Console, I get a 404 error.
Here is the diagnostic log:
Any advice for a software guy who is needing to get this switch up and running? Thanks!
Leo Laohoo
Console into the switch and post the complete output to the command "dir".
I suspect the HTML files are either missing or in the wrong directory.
