Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3592 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5274 Views
  • 1 replies
  • 16 Helpful votes
I am trying to:create ACL for each server and configure NAT for the ACL where I  map private IP addresses to public IPs. Which command can I use to achieve that in CLI for a CBS 350 series ME-switch
brucenelm by Level 1
  • 267 Views
  • 1 replies
Curious to know if others are using "qos basic" or "qos advanced" to support voip (Deskphones using voice vlan).I'm trying to see if I can get by with just "qos basic" and "priority-queue out num-of-queues 3" so as to not overly complicate things in ...
jason-g by Level 1
  • 450 Views
  • 1 replies
Hi,I have a SG350-10P switch running the last 2.5.5.47 firmware.The switch is set to factory defaults. Has yet to be programmed.I noticed that my access points didn't get any power. Checked with an external PoE adapter, AP working fine. Just not with...
I am looking to increase redundancy at a site by implementing HA with firewall.  Currently only have single deployed but have purchased a second & starting to work on the connectivity.  The firewalls are FPR1140's, while the switches are CBS350-24XT'...
brisen by Level 1
  • 870 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
