Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 803 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5621 Views
  • 1 replies
  • 16 Helpful votes
Hi, I have two SG 300 working on my vSphere Homelab. Now I want to reconfig some VLANS and I get some mysterious views at the web frontend: - I'm on the Port VLAN Membership Table an select 'Join VLAN' I get the Popup but everything is empty: - On ...
SMaurer01 by Level 1
  • 506 Views
  • 0 replies
I'm playing with an SF300-24P switch and want to connect an IP Phone.I'm more familar with IOS syntax than the SF300 GUI.How would I replicate the following in the SF300:Switch(config)#int fa0/1 Switch(config-if)# switchport mode access Switch(config...
I am trying to configure properly a radius mac auth for specific port on a sg300 switch. Schema : Router --> Switch --> AP --> Client My client need to authenticate L2 via mac on the switch and go on the right vlan. I tried a lot of thing, but I can...
iLevac001 by Level 1
  • 423 Views
  • 0 replies
I configured route map with next hop to specific vlan but after I configured it this vlan can't reach the other vlans, but I need this vlan to reach one host in another vlan. this is my configuration that I did.  interface Vlan120description wifi-ipa...
We have SG500's and SG220s all setup for RADIUS & for some reason the SG220's act differently. When you first SSH to them it asks for you username, as soon as you enter it the screen flashes and then it asks for your username & password to access the...
Hello there,In my network I got 3 SF300 24 p switches. I managed vlan 10 for data and it is also a native vlan and vlan 20 for voice.1st switch is the core switch here is configurationswitch7e6333#sh startinterface range fa10,fa18storm-control broadc...
nrajkovic by Level 1
  • 7355 Views
  • 9 replies
I have a SG300-10MP that is connected to a Ubiquiti Gateway switch on port 1. Even though I have POE enabled the ports do not provide power over ethernet, otherwise they function normally. I have even reset the switch to the default settings without ...
Hi All, I recently setup an SF300-24 with a complicated configuration.  At the end of the configuration I reset the password to a password that had three criteria's  the password is 10 chars long, lower case, special char, and a number.   The proble...
nathan by Level 1
  • 583 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
