Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 774 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5606 Views
  • 1 replies
  • 16 Helpful votes
I have 2 SG500XG-8F8T switches and 3 SG500 switches. each set up in there own stack Currently SG500 running at 5G and SG500xg running at 10G between them.. with a 1G connection connecting the 2 stacks. Is there a way to get all 5 switches in the same...
krob20041 by Level 1
  • 418 Views
  • 0 replies
Hi, I have setup a SG300 (in L3 mode) as below but can't solve what I thought should be a simple problem, but cannot for the life of me figure it out. PC1 and PC2 can ping each other and 192.168.1.100 (port GE1). So I'm happy that VLAN setup and DHCP...
Simon DM by Level 1
  • 487 Views
  • 1 replies
こんにちは。SG300-20JPを6台所有しています。 fw-1.4.5.02、boot-1.3.5.06 で統一しています。 うち1台だけ Green Ethernet > プロパティ の画面で 802.3 Energy Effcient Ethernet (EEE) のチェックボックスが存在しません。 試しにCUIで接続し、#show eeeと打ち込んでも Unrecognized command と返されます。 Green Ethernet > ポート設定では、ポート設定の編集ポップアッ...
vsmadoka by Level 1
  • 550 Views
  • 0 replies
hi, i recommended a Cisco switch for my workplace because i learnt it was the best. they finally brought in SF 100-24 (small business) switch. but the problem is that i cant seem to configure and work with it at all. when i connect the computers thro...
kivoo4all by Level 1
  • 452 Views
  • 1 replies
Hello, So, I just got a SF300 switch for our small business. I am trying to configure it but i am a little confused. I have set the switch to layer 3 mode and accessed it through the CLI. I have created a new VLAN and assigned it all 24 Fa ports, I ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
