Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3592 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5274 Views
  • 1 replies
  • 16 Helpful votes
My company has been having a few issues recently where SG300-28A switches 'go dead' to field locations. When they arrive back to us we take a look at them and are prompted for the MAC address, serial number, and hardware version. After a lot of fight...
rkendrick by Level 1
  • 1853 Views
  • 2 replies
I have a question, if I configure a SPAN session on a pair of Nexus 5500's in which the source is a server plugged into a FEX, and the destination is a server plugged into each of the 5K's via a 10gig breakout port (the default ports on these 5K's be...
I have setup a link aggregation between 2 Cisco SG300 network switch. I had assign port 1 and port 2 (both are Gigabit port) as a member of LAG1. From the Cisco switch GUI,it is shown that the both port is an active member. In this case, will the LAG...
Dear Sirs. My brand new SF500-48P switch seems to have problems while operating with PoE enabled. When I try to enable power on port #1, for example, the power is enabled on port #2, and so on. I tried resetting the device to factory defaults, as wel...
AlexioUBS by Level 1
  • 887 Views
  • 2 replies
Hello and Happy New Year. We are getting ready to buy 8 48 port switches.  We have a Meraki MS220-24P That has POE. We do not need POE on these and I would like to just go to Cisco regular switches. I see a bunch of options.  I know we want managed ...
todd by Level 1
  • 940 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
