Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Bookmark
Subscribe
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3706 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5391 Views
  • 1 replies
  • 16 Helpful votes
My company has been having a few issues recently where SG300-28A switches 'go dead' to field locations. When they arrive back to us we take a look at them and are prompted for the MAC address, serial number, and hardware version. After a lot of fight...
rkendrick by Level 1
  • 1882 Views
  • 2 replies
I have a question, if I configure a SPAN session on a pair of Nexus 5500's in which the source is a server plugged into a FEX, and the destination is a server plugged into each of the 5K's via a 10gig breakout port (the default ports on these 5K's be...
I have setup a link aggregation between 2 Cisco SG300 network switch. I had assign port 1 and port 2 (both are Gigabit port) as a member of LAG1. From the Cisco switch GUI,it is shown that the both port is an active member. In this case, will the LAG...
Dear Sirs. My brand new SF500-48P switch seems to have problems while operating with PoE enabled. When I try to enable power on port #1, for example, the power is enabled on port #2, and so on. I tried resetting the device to factory defaults, as wel...
AlexioUBS by Level 1
  • 902 Views
  • 2 replies
Hello and Happy New Year. We are getting ready to buy 8 48 port switches.  We have a Meraki MS220-24P That has POE. We do not need POE on these and I would like to just go to Cisco regular switches. I see a bunch of options.  I know we want managed ...
todd by Level 1
  • 955 Views
  • 4 replies
Installed one of these at a client, and cannot access the PoE management on the Web interface. Thought perhaps it was the browser preventing, but the same issue occurs in Chrome, Edge, IE and Firefox.  Switch currently running 1.0.0.17 firmware, but ...
titanpcs by Level 1
  • 2068 Views
  • 8 replies
Hai , Cisco Catalyst 2960 series switch showing " Press Return to get started " when connect using Teraterm . using this message not possible to enter in switch settings .How to solve this issue or skip from this message . Error message has been upl...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
