Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3590 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5274 Views
  • 1 replies
  • 16 Helpful votes
Hello i have purchased sf300-48p and start its configuration very well but i face a problem so you can help me in this one i have created 3 vlan vlan 1 default   interface ip  192.168.1.254 /24  vlan 16   interface ip  172.16.16.16 /24 vlan 23   inte...
I currently have a Comcast Cisco Gateway DPC3939B connected to the GE1 port on my SF200-48 switch. I cannot attach to the management on the DPC3939B through the network without the management site failing to load. Does anyone know if I should be chan...
ihmtech01 by Level 1
  • 551 Views
  • 1 replies
Hello, After a lot of struggle with registeration i registered.This is my first post.I am using Cisco SG300 28 port managed switch.I want to know that is their any option in the swicth by which i can track usage of each host connected to its port us...
Hi, We've got two Cisco SG500X-24 switches that we wish to link together with a 20 gig link over ~300 metres of fibre. Can this be achieved using the two 10G stacking ports (ie can stacking ports be aggregated?) or would we need to aggregate the tw...
For some reason my configuration doesn't show the native vlan as 100 or 100 in the allowed vlan list. Is this because its my default vlan? Just noticed I'm loosing connection randomly from this switch to my network. Both sides of the port group are c...
jbpollard by Level 1
  • 2202 Views
  • 1 replies
I am working with an SG200-26P.  I have the Voice VLAN configured as VLAN 200, and the Data VLAN configured as 101 for workstations.  When I plug in a workstation, everything is fine.  When I plug in a VOIP Phone, the VLAN membership changes to 1 and...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
