Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2647 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4178 Views
  • 1 replies
  • 16 Helpful votes
Hi, I'm not sure if anyone else is experiencing this, but changing the device IP and native VLAN has become more difficult.There is no comprehensive, detailed documentation on either of these operations in the devices support portal.  I've looked eve...
AbbyDoc by Level 1
  • 634 Views
  • 3 replies
We have an SG350 that will not recover from this loop on boot. Tried to restore factory defaults but no success.  What are our options?  ***** FATAL ERROR *****Reporting Task: HCPT.Software Version: 2.3.5.63 (date Aug 20 2017 time 19:03:04)ros(HOSTG_...
I've just purchased a CBS350-48T-4X - my first fully managed switch so I'm using the web GUI. I'm trying to set up a VLAN for our voice traffic.VLAN1 obtains an IP address from a DrayTek router - used for broadband accessVLAN20 obtains an IP address ...
GDoggy by Level 1
  • 2043 Views
  • 6 replies
I am having an issue setting / changing the DSCP value with CBS350 switches. I have an IPv4 Access List associated with a QOS policy to "set dscp 34" and that ingress policy is mapped on all ports of the switch. When pulling a wireshark on one of the...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
