Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 753 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5595 Views
  • 1 replies
  • 16 Helpful votes
Hi, I have 1 no. SG300 -28 SFP and around 10 Nos. SG300-28PP switches in my network. I wish to configure two VLANs in my network and inter VLAN routing. SG300-28 SFP in on top of my network which is connected with all 10 nos. edge switches i.e. SG30...
HiFirst I want to say I am not a native English speaker and I'd apologized for grammatical mistakes that my text might contain. Thank you for your understanding. My equipement : Switch SG300-10 , setup on layer 3   Here my configuration:vlan 2-4,100e...
AndrewL by Level 1
  • 5685 Views
  • 11 replies
Hello,I have an SG200-26P currently running the latest firmware of 1.4.1.03 in my network.I have a basic need with this switch. Provide the fastest transfer of data between my router and the 7 access points that are plugged into it in our classrooms....
Hello all, its been a while I've configured a small network and was looking for information. I have a closed network system that I am configuring. I would like to divide the network so that all devices can only speak to Q (bidirectional) but not each...
I am new at this, and need assist in updating the sx200_boot-13506.rfb file into my switch.  I have downloaded the Boot and FW files to my computer which is connected to the switch, and updated the fw file by using the Upgrade page via HPPT/HP\TTPS a...
fladd by Level 1
  • 6089 Views
  • 6 replies
Hello we have a sg-300 with latest firmware.  I'm trting to replace a Netgear switch that has this:ip helper-address 10.1.10.8 dhcp  I thought this would work:ip helper-address all 10.1.0.8  however show running-config shows port 67 is not helped:ip ...
fbcadmin1 by Level 1
  • 959 Views
  • 4 replies
Resolved! SG300 VLANS
Hi,I have 4 SG300-28P switches in L3 mode.They are connected to a Netgear FV336G Dual WAN router which provides 3 networks (VLAN1, VLAN 30 and VLAN 40), it has 3 different DHCP scopes for each VLAN. VLAN1 = 192.168.101.x, VLAN 30 = 192.168.30.x and V...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
