Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2609 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4142 Views
  • 1 replies
  • 16 Helpful votes
I feel that it's a security risk to have a port set up as anything other than Access if it's only going to have "dumb" hosts plugged into it (i.e., printers, workstations, etc.).  So, I usually only assign the management VLAN as the PVID of a trunk p...
If I don't have any VOIP devices, should I just leave all the QoS settings to default? We have an AirPlay speaker on our network, so could there be benefits in raising the QoS priority so that the audio streams smoothly to this device?Cheers,Max
maxhodges by Level 1
  • 980 Views
  • 3 replies
I hardly understand any of the features on by SG200-18 switch. Where I to even begin to learn what this stuff means? I wonder if I should change any QoS settings but I have no idea what most of this stuff means (the administration guide assumes you'v...
  • 621 Views
  • 3 replies
Resolved! LLDP MED Issue
Hi,We have a SF300-24P with the version 1.3.7.18 and LLDP MED isn't working with IP Phone Yealink T28.The phone advertises via LLDP in the TLV Type(127), TIA-TR41 Media Capabilities with Network Policy Capable showing that it is able to receive the v...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
