Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 732 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5590 Views
  • 1 replies
  • 16 Helpful votes
hi, having upgraded two sg300-20 (firmware 1.3.7.18) with fibremodules "cisco MGBSX1 V01". Fibreline is working fine, but the Status Page in the WebGUI shows no data, only N/S N/A values ... ?with an old firmware, data was shown!whats the problem? th...
m.lang001 by Level 1
  • 363 Views
  • 0 replies
Hello, I have two SG500XG-8F8T's in a stack config.  I am using the 10G copper ports 1/2/1 and 1/2/2 to connect to a VNXe SPA eth10 and SPB eth10 respectivley.  I have ports 2/2/1 and /2/2/2 connnect to SPA eth 11 and SPB eth11 repectively.  The port...
rchew by Level 1
  • 1268 Views
  • 7 replies
Hello, I have a switch that when turned on the System light starts blinking orange. When I connected to the switch with the console cable I got this: Image Loader 1.0.1                  Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix    ...
MataKiera by Level 1
  • 673 Views
  • 2 replies
Ever since installing SG500X switches in my network, i have had issues with database disconnects. I have 2 SG500X stacked together. I have many LAG groups spanning the 2 switches for redundancy. I recently installed an iSCSI SAN for 2 physical vmware...
Hello,I'm using for one part of our small business network a SG100D-08 EU switch.For an unknown reason, this switch is not working at one location. When connected to a laptop, the laptop is not getting an IP address.If I replace that Cisco switch wit...
I am trying to increase our phone quality issues. Things like backup tapes, heavy download etc are causing the phones to get all crackly. I am not sure where to start. Everyone says VLAN's but I don't know if that's the best choice. I don't know anyt...
broomstar by Level 1
  • 1736 Views
  • 10 replies
I am using an SFE2000 in a small business setting.  With nothing going on, the switch is reporting 100% CPU utilization.  lcli usage is very sluggish.  We have been experiencing some slowdown on the network, and this could explain it.The lights are n...
Hi,Some questions:1. Do we need to upgrade the boot code every time the firmware we need to load is 1.3.5 and above?2. What do we need to load first boot code or firmware? or any order will do?3. From the notes below. Do we only need to update the bo...
josephm2 by Level 1
  • 512 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
