Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3252 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4798 Views
  • 1 replies
  • 16 Helpful votes
Is there a proven working config for a CBS350 switch for using Microsoft NLB similar to the one available for other Cisco switches like the Catalyst.https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/107995-configure-nl...
nadm by Level 1
  • 220 Views
  • 1 replies
Can you please assist me walk me through to setup for Sonos:Log into the router's administration panel and navigate to L2 Switch > RSTP and check 'Protocol Enable' on all ports”What we found was that you need to configure the 'main switch' to use the...
I have 2 network switches at one end Switch 1 & 2 and 2 network switches at the other end Switch 3 & 4. SWITCH 1 IS connected to Switch 3 on a uplink and switch 2 is connected to switch 4 on another uplink using a different media creating are redunda...
tecindia1 by Level 1
  • 301 Views
  • 3 replies
Hi all,I have a cisco cbs350 switch and C4000 modem,  when i turn the modem into  transparent bridge mode the switch port flap. the switch port is normal when it is at auto connect to internet. Regards,Prem.
I have a 3850 48P, that was pulled from a 3 switch stack.This switch is no longer going to be part of that stack.It is currently on version 16.6.4, want to put on 16.12.12When I try to load  the ios, get the following messages.cisco WS-C3850-48P (MIP...
StarLog by Level 1
  • 394 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
