Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3595 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5278 Views
  • 1 replies
  • 16 Helpful votes
I'm helping someone setup a network in their new office and want to see if my equipment selection is correct.  The products of the Small Business suite seemed to meet our needs as best I could tell. There is a dizzying array of products to choose fro...
mzeilenga by Level 1
  • 1247 Views
  • 4 replies
I inhereited a network setup when I was hired in Febrary of this year, and I'm still figuring things out.I have 2 switches in a server rack.One is a Cisco SLM2048, Ip address 192.168.1.254I can log in and administer it fine.The second is a SG200-50, ...
rwkinney0 by Level 1
  • 3170 Views
  • 7 replies
                   I purchased this switch as an affordable way to deploy POE and to verify QOS marking if the need arises.I have connected NEC phones and have confirmed via Cisco 2960's that the phones are marking EF (DSCP 46) correctly.  I then rep...
gmacisco1 by Level 1
  • 1082 Views
  • 4 replies
Hi all,I am a novice at networking. I have a Cisco SF300-24 devices support PoE, PoE mode on my already enabled. But when I try to connect with wireless radio devices, devices that I connect does not turn on. Is that a problem? Thank you for your hel...
HiIs it possible to configure two SG300 switches to be resilient so that if one were to fail the other instantly takes over and the network continues to function? I've not been able to find anything out about this, but that could be because I am not ...
On a Cisco SG500-52 Small Business switch, I generated a new 2048-bit RSA private key and generated a Certificate Signing Request to submit to a CA. I received the new certificate from the CA and tried to import it in to the SG500-52 switch. (Firmwar...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
