Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3572 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5254 Views
  • 1 replies
  • 16 Helpful votes
Resolved! SG-300 LAG speed
Dear forumers,I'm configuring two SG-300 switches at the moment, and I'm trying to connect them with two cables.I've set up the LAG like this (on both switches): LAG001.jpg And a got the following result: LAG002.jpg This means my connection is at onl...
Hello,We have small network with 15 Computers all connected to SRW224G4 . After a power brake our switch dosent "boot"  anymore. I see all leds working flashing etc but no network acces, no Serial acces. When i try connecting to serial port and "rese...
Help!I have just received a Cisco SF 200E-24P switch and need to upgrade the firmware. The current version is 1.0.0.12 an need to load the latest (or at least 1.1) to get CDP etc. However when I use the upgrade option in the switch I get an error of....
simon by Level 1
  • 3950 Views
  • 4 replies
Hallo,can you please explain me this problem more in detail, please:##################################################################Problem: When a DVA authorized port tries to re-authenticate and RADIUSattributes no longer include VLAN attributes,...
We have VLAN 1 disabled on our standard Cisco Catalyst switches and use VLAN 11 as our default.  We have recently added VLAN 221 for voice while implementing a new Cisco UC system.  I can't seem to disable VLAN1, however, I have made the default VLAN...
Hello,   I have 2 SG300 switches and all I want is to propagate VLAN info from one to other.   I do not have computers with GVRP compliant NICs, so I dont want that auto registeration functionality on access ports. I want VLAN prop via trunks and swi...
I'am testing a sg300 switch in layer 3 mode and created different vlansvlan1: 172.16.0.0/16vlan4: 192.168.4.0/24I inserted a default route to our internet router (172.16.0.55) and there a route back to the switch 172.16.2.101I defined no acls at the ...
wehner by Level 1
  • 2049 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
