Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 751 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5594 Views
  • 1 replies
  • 16 Helpful votes
Hello,I have a SGE2010 and have one static LAG going to each of my (two) ESX servers.  From my testing it seems that the LAG speed is maxing out of 1Gbps.  I am unable to get anything faster than that.  I cannot find the load-balancing algorithm that...
Pcfreek14 by Level 1
  • 1053 Views
  • 0 replies
I recently got an sg200 switch and was surprised to see that the switch just collapsed after i started a 1gbps transfer between two internal 1GbE interfaces, the cpu was reaching 100% and no other port was working. This is really bad - is this switch...
ricveloso by Level 1
  • 776 Views
  • 0 replies
I am in the process of trying to replace a modem/router,the switch does not work with the new modem/router although if I connect the modem/router directly to my computer it works fine,so its not a router issue.I suspect that the settings need to be c...
mail by Level 1
  • 1350 Views
  • 3 replies
HiWould be nice if someone could show us the light at the end of the tunnel.Got 4 Cisco Switches 2 x SG300 and 2 x SG200.All the switches are connected via fibre cable to each other.Trying to setup 2 VLAN's on the switch :1st VLAN normal network traf...
CT_Dude by Level 1
  • 37648 Views
  • 7 replies
We setup about 5 MAC based VLAN groups with about 40 MACs total and now we are getting "There are no resources for this range.." when we try to add more MACs or try to assign them to the port/VLAN "MAC-Based Groups to VLAN".  We tried to reboot and u...
DearI have sf300, i didn't found the option to telnet it.default IP of the switch is 192.168.1.254, i can access it by HTTP.also i'm not able to attach IP phone on voice vlan & computer on vlan 1please share the step by step guide how to access the s...
hi I  Have been facing a problem, like when  we are connecting the Aironet LWAPP  indoor  Accesspoint to Cisco SF300-24P Switch, we are getting some error like LOW POWER...means accesspoint not recieving enough  power from POE Switch.As per Cisco Dat...
I'd like to use an SG200 swicth to allocate bandwidth on a 100 Mbps fiber Internet uplink.I will have 5 routers (each supporting a separate network) connected to the SG200, and I'd like to give each network 20 Mbps.I would greatly appreciate it if so...
Hi Would it be possible to change output style of "sh running-config" in SF-300 switches to Cisco IOS-like format (eg.: options related to the specific interface put together, add tabs) in the next release? That would be much more readable.Thanks for...
Hi, i just got a sf300 and i need to break down my network to create different subnets.actually i am using the 192.168.1.0 /24 subnet.what i need to do is to subnet my network so that the different vlan cannot talk to each other.for e.gvlan 2 is data...
As described in older archived thread, is there any resolution or progress on this issue?Issue that I'm having is the same as somebody else had, quoted below:"The network is up and appears fine, but when I make any physical port  changes (unplug one ...
Hello.... I finished upgrading  6 SFE2000P Switches to software version 3.0.1.0, however I do not see any information about the boot version. The switches now have 1.0.0.05 and the one that came bundled with software upgrade 3.0.0.16 and 3.0.0.17 is ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
