Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 926 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5702 Views
  • 1 replies
  • 16 Helpful votes
Hi,Can any one help me in how to access the CLI mode in  cisco sf 302-08p 8-port 10/100 Managed switch. I treid the every method they mentioned in the Admininstration guide.I am not able to enter the command debug-mode and comand menu after resetting...
Hello,I have problem with device SG 300-28. When I try to set port mirroring I get following message: “Lock port Dynamic Enable prevents executing Copy Port Enable”. This message is displayed as in web-interface, as in lcli mode. This is output from ...
I am looking for a how to configure a DHCP server for a Cisco SMB 300 series switch to obtain an automatic configuration. Currently i am using a Cisco 1800 router as my DHCP server and the DHCP pool serving the 300 series switch is configured as foll...
hellow,I bought 3 switches (gs 300-28 ports)and i need to connect them to my network, when all the switches are cisco 3560g, with vtp on the vlans.my question is, how to creat vlans on this switch? and Is it possible to make the gs300 learn the vlans...
Hi,We have 3 SGE2010P all set up as layer 2 switches with no DHCP, no VLAN configuration. They are just acting like switches. We are a small office of about 100 people so there is no need for me to configure anything on the switches. I have a problem...
troyday88 by Level 1
  • 1525 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
