Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3595 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5280 Views
  • 1 replies
  • 16 Helpful votes
Dear all,I have configured the two L2 SF200 switches connected uplink to L3 but when we connect back-2-back SF200 we are getting looped. Kindly support to provide the sample configuration @ your earliest. attached is my configuration, what I want tha...
MAKhan by Level 1
  • 794 Views
  • 0 replies
We are about to install a new VoIP system (Allworx, which I did not select) and need to set up a new VLAN with QOS quickly for my SG 300 and SG 200 switches.  I have the default VLAN1  at 10.0.0.0/24 and will be setting up VLAN10 at 10.1.0.0/24 for v...
GastonMfg by Level 1
  • 1385 Views
  • 1 replies
Hi,We bought 2 new small business SG300-20 switchesI've been looking into configurating them. They work fineBut i also found this "host mapping"I filled in an IP + DNSbut when i then try to ping the name it can't find it.What should i do to get it ri...
steven.dw by Level 1
  • 868 Views
  • 0 replies
We have a stack of 2 SGE2010s and 1 SGE2000. They are set to layer 3 mode and are routing between several VLANs.  There are also several static routes, each representing a building on our WAN.  The WAN is a leased fiber connection with 10 Mb/s of ban...
I wanted to run this plan by some others before I screw something up.Client is adding 2nd WAN link via wireless.  There is not additional cabling from the wireless location down to the control room but there is a switch nearby.  All switches are ESW-...
ambleside by Level 1
  • 2570 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
