Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2609 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4142 Views
  • 1 replies
  • 16 Helpful votes
Hi folksI currently have a network for a client that needs re design. the customer are currently using unmanaged Netgear switches. their current network topology consists of two leased lines both being routed by two cisco routers (1 1800 & 1 800). th...
Hello,I have a ESW 540 48 port gigiabit switch.  We have had it a year and a half.  In the past year it has experienced this cycle of problems:After a reset, within a week the fans are on full blast. Within less than a month the webgui is gone - not ...
I'll try to make this simple:I setup my DHCP server in the switch then added the VLAN that I want to forward for.Running Wireshark on my server:I can see the DHCP Discover from the foreign VLAN coming from the swtich.My DHCP server responds with a DH...
DJX995 by Level 3
  • 1654 Views
  • 3 replies
Hi. I've just received an SG 300 and am in the process of tuning the configuration. We have a couple of compute servers that have been behind a PIX 515e that we would like to move over to the SG 300. Is there a way to enable / configure the SG 300 to...
HiI've recently inhierited a network which relies on a couple of SGE2000 network which has multiple vlans configured, unfortunatley i am unable to get to the management ip of the device to look at the config. I have put in a serial cable it see that ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
