Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 943 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5708 Views
  • 1 replies
  • 16 Helpful votes
Decided we'd give the Cisco 300 series switches a try and seewhat we think about them compared to our Cisco Catalyst 2960 switches.I'm already stumped on setting up VLAN trunking between 4 switches. Do I have to manually setup all the VLAN's on each ...
Hi there,we're trying to setup a VLAN trunk between a new SG300-28P and an existing SRW2024P (Linksys/Cisco)both ports are set to trunkboth ports have VLAN 1, untagged and VLAN 2 taggedVLAN 2 exists on both switchesthe link works if we put an 8 port ...
converged by Level 1
  • 2341 Views
  • 0 replies
Resolved! I need a Switch
I am currently a student working on a project that has me designig a network for a small business. So I was hoping that someone could suggest what switch(s) I should use from the Cisco product line. I am going to need approximatley 285 ports split up...
g.e.bewick by Level 1
  • 2273 Views
  • 20 replies
I do know that the current ESW 500 switch models do not have enough capacity to power all of the switchports at 15.4W, even though the ESW-540-8P model has almost enough capacity to power all of the switchports at 15.4W.Reasons why new ESW 500 switch...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
