Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2608 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4141 Views
  • 1 replies
  • 16 Helpful votes
Hello Everyone,Recently purchased some 1000Base-T Mini-GBIC SFPs (MGBT1) under the impression that they were full-fledged Cisco devices with intent to use them in our 3560G-48TS. As I hotplug them in, I receive the following:%GBIC_SECURITY_CRYPT-4-VN...
If I make a change to the config on my SGE2000P via the GUI, do I manually have to save the running config to the startup config like in Cisco land, or does it behave like a Linksys where as soon as you click "apply" the change is automatically saved...
jlixfeld by Level 1
  • 3062 Views
  • 1 replies
Can someone confirm the following is correct:ESW-520 Series (10/100) - Total No. of ports = 24 / 48 + 4 Expansion Ports:i.e.Cisco ESW-520-24 - 24 + 4 = 28 Ports in TotalCisco ESW-520-48 - 48 + 4 = 52 Ports in TotalCisco ESW-520-24P - 24 + 4 = 28 Port...
phershaw by Level 1
  • 2963 Views
  • 1 replies
Hello,Just installed a new 2960 switch.Everything is working except that I am no longer to uplink a small unmanged linksys switch that is leftover from previous configuration.I am using x-over cable and have tried adjusting switchport modes.If I use ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
