Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2609 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4141 Views
  • 1 replies
  • 16 Helpful votes
Hello, I have a SonicWall NSa 3700 firewall, Tripp-Lite KVM, and Cisco SG350XG-24T switch. I connected my Cisco switch OOB port to one of the firewall interfaces and the Tripp-Lite KVM to two firewall interface using Transparent IP Mode (Splice L3 Su...
alsayegh by Level 1
  • 613 Views
  • 2 replies
Hi, My SSH command "user@<IP>" in Cisco CBS220 does not accept a user and not promt a password, next displays a prompt to question a username and password, I was trying to use ansible to set up the switch but I have this problem.With telnet I can res...
psilva by Level 1
  • 2162 Views
  • 9 replies
HiThe documentation for the CBS 110 series seems to imply that all models can be rack mounted, is that true?I find it hard to believe that the smallest can.  Can anyone confirm this, and if not correct, can you tell me which ones are rack mountable (...
mike_t2 by Level 1
  • 1793 Views
  • 5 replies
Hi, I need help for Cisco RV160W router WAN QoS profile configuration change for Low default to Highest Please help me how to configuration QoS. I am using two Cisco SF300/24 connected with RV160W. Please make screen shoot image and step by step How ...
I have cisco SF300 Switch, how i configure to each PORT 1-24 and all MAC QoS DSCP value 6Mbps and LAG Port Channel for every AP 6Mbps, I need more dozens Cisco SF/SG Series Switch for my Networks. I need easy to manage Bandwidth.Foysal ISP Broadband ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
