Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3576 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5263 Views
  • 1 replies
  • 16 Helpful votes
i want to list and show the VLAN-id and VLAN-name by api (json) from Cisco busniess Dashboard , how can i do thati found just put methode not getreferneces:https://developer.cisco.com/docs/business-dashboard/#!api-referenceput /v2/nodes/{nodeId}/conf...
Hi all, I'm new here so please be kind!Bought an SG350-10 switch recently to use in my home labI'm setting a static IP on the switch and all is working fine.. I've got this plugged into an older ASA5505 that has no DHCP configured on the port plugged...
Hi,My backbone switch is constantly producing traffic from switch itself to  224.0.0.251:5353 in every 5 seconds.I learned that it is bonjour traffic which i dont need.Therefore i globally disabled bonjour discovery from the switch but i couldnt stop...
akanarya by Level 1
  • 1362 Views
  • 4 replies
I tried Cisco Configuration Professional for Catalyst for the initial setup of a Cisco Catalyst 2960L-24TS-LL. I ended up falling back to the good old console and upgraded the software to c2960l-universalk9-mz.152-7.E. If I set authentication local f...
Dwokfur by Level 1
  • 2577 Views
  • 11 replies
HiI am trying to monitor a SG220-26P switch in my network using Cacti. I'm unable to find the OID for CPU, Memory and Temperature. The only one I've found that works so far is for System Uptime (generic interface ones work a treat too) and have tried...
I created my network in the following order:Set up an RV340 router, using its GUISet up an SG350 switch, using its GUISet up a few 140ACs, using the main AP's GUIInstalled a Cisco Business Dashboard (CBD)The CBD discovered the existing equipment:Requ...
WesMC by Level 1
  • 715 Views
  • 0 replies
I've connected recently on an SG500X and an SG500  several devices and all of a sudden the port VLAN settings change to default, PVID1, and Tagged all available Vlans. In an instance, I connected a Yeastar PBX on an untagged vlan40 port, and all of a...
zgeorgios by Level 1
  • 381 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
