Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2609 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4143 Views
  • 1 replies
  • 16 Helpful votes
Hi,Expecting your valuable support to find root cause of intermittent /random network disconnection happening for intervlan (intervlan routing handled by firewall) & intra vlan communication.Please find the attachment.01. Network architecture.02. All...
Hi All I have a SG300 with the latest firmware. I have two modems attached to it via ethernet. DHCP is turned off on each modem so I'm using the SG300 to assign IP's via DHCP Server. Let me explain. Modem 1 : LTE Modem with static IP 10.0.0.2Modem 2 ...
We have a mix of SG200-26 and SG220-26 small business switches.  I am in the process of converting over the management logins for these switches to use our on premises RADIUS Server, a Windows Server 2016 NPS box.  The SG220's are working fine, but t...
Hi,Nearly we had problem with Cisco Switch SG350XG 100% CPU, almost not importand features was disabled.Almost my device still working but some time it delay.Some people post the same issue with me but no one was resolved.Any body help me how to fix ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
