Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3590 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5274 Views
  • 1 replies
  • 16 Helpful votes
Greetings Everyone,I am having a Cisco Small Business SF300-24P Switch and I'm trying to connect it to an avaya phones and it's giving me the headache of a lifetime for 3 days now. I've tried all sorts of switchports and Voice Vlan settings and LLDPs...
My SG500XG-8F8T-K9-NA Serial DNI18310260 has stopped working, If I connect the power the master and fan leds are green solid but system led stays blinking fast. If I connect a laptop via ethernet no led blinks or turns on on the port, I have tried us...
I have recently purchased 2 of the above switches and am a little unsure on how to trunk the two switches together. They are in separate rooms joined by a length of ethernet cable on ports 28 on each switch. On each switch we have the default vlan1 a...
Skully32 by Level 1
  • 778 Views
  • 3 replies
Hello,When running command " show interfaces counters fa 5" on cisco sf302 switch we didn't get the full data value together as shown in the figure below. in OutOctets the value should be 1142444759851 displayed by single value at the same line not a...
Resolved! Layer 3 switch
Good morning  I have in my office a small modem with 6 connection ports. I would like to connect a layer 3 switch in eat so that I can have 2 vlans one that can see the internet and one that will not be able to see the internet. Is this possible ? wh...
Okami11 by Level 1
  • 825 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
