Connect old catalist 1900 to small businness SG500
tecnopluscgall
Hi all.
I'm having trouble confighuring and make it work a small businness SG500 with a sfp transceiver.
We had two old Catalist 1900 C.They were connected throw their 100BASEFX Port.
One of them stop to work.
The client buy as replacement an SG500 + cisco MFEFX1SFP and we are having problem to make it work.
Firstable: the two switch may communicate in this configuration?
IN the small businnes i can see the sfp is recognized correctly, the show a green ligth on one of two led but on cisco1900 no ligth at all.
This is the actual conf of 1900 are:
Catalyst 1900 - Port A Configuration
         Built-in 100Base-FX
         802.1d STP State:  Forwarding     Forward Transitions:  278
      --------------------Settings------------------
      [D] Description/name of port
      [S] Status of port                              Enabled
      [F] Full duplex                                 Disabled
      [I] Port priority (spanning tree)               128 (80 hex)
      [C] Path cost (spanning tree)                   10
      [H] Port fast mode (spanning tree)              Disabled
Catalyst 1900 - Port B Configuration
         Built-in 100Base-TX
         802.1d STP State:  Blocking     Forward Transitions:  0
      [S] Status of port                              Suspended-no-linkbeat
Could be these conf be the problem?
Any one could help me or giove me hints to go aout of this troubles?
Besta regards,
Carmelo GAllucci
Brandon Svec
Level 7
Level 7
I'm only guessing, but I would try full duplex on the 1900.  I would also try to hard code the port on the new switch to 100Full as I am pretty sure it defaults to 1000 and will probably not auto negotiate to the 1900 with the setting you show.
-- please remember to rate and mark answered helpful posts --
hello brandon.
I've done a try configuring new switch half duplex 100.
Now i tried your suggestion but nothing happens.
folowing the actual conf. do you see same of strange or errors?
switchfc3504#show interfaces status gi1/1/49
                                             Flow Link          Back   Mdix
Port     Type         Duplex  Speed Neg      ctrl State       Pressure Mode
gi1/1/49 1G-Combo-F   Full    100   Disabled Off  Up          Disabled Off
     Built-in 100Base-TX
     802.1d STP State:  Disabled     Forward Transitions:  0
  [F] Full duplex                                 Enabled
     Built-in 100Base-FX
     802.1d STP State:  Forwarding     Forward Transitions:  281
Carmelo
