10-12-2020 08:11 AM
I am considering purchasing 2 SG350X-48-K9-EU and 2 SX350X-12-K9-EU. i can stack them with FC cables. it's possible ? or I can only use copper. if you have to take the cable with connector or transceivers + fiber cables
Solved! Go to Solution.
10-14-2020 01:22 AM
Hi there,
That is correct. You can choose whichever option based on your needs - either using the SFP copper coax SFPs or any of the fibre optics SFPs. For the fibre optics connection, you will need an optical fibre cable (or optical patch cord) with LC connectors at the ends. If you have to cover greater distances the multimode fibre cable should be at least OM2 (>82m@10GE and >550m@1GE).
Martin
10-12-2020 09:20 AM
You need use right cable as advised, you can not use any other one.
look below document :
10-14-2020 01:01 AM
Hi Balji,
i can use this cable or transceiver ?
SFP-H10GB-CU1M= Copper coax 10 Gbps 1 m
SFP-H10GB-CU3M= Copper coax 10 Gbps 3 m
or this transceiver:
SFP-10G-SR= Multimode fiber 10 Gbps 26 m to 400 m
SFP-10G-SR-S= Multimode fiber 10 Gbps 26 m to 400 m
Thank you very much
10-12-2020 11:29 AM
You can stack up to 4 units in a stack with a total of 208 ports managed as a single system with hardware failover. In your use case, you have to deploy so-called hybrid stack mode due to the different switch models. Your stacking ports are the XG ports. More information about how to configure stacking is available in the product administration guide:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
Supported SFPs that you can use also for stacking are listed in the below table
Supported SFP/SFP+ modules |
SKU |
Media |
Speed |
Maximum distance |
MGBSX1 |
Multimode fiber |
1000 Mbps |
500 m |
MGBLX1 |
Single-mode fiber |
1000 Mbps |
10 km |
MGBLH1 |
Single-mode fiber |
1000 Mbps |
40 km |
MGBT1 |
UTP Cat 5e |
1000 Mbps |
100 m |
GLC-LH-SMD= |
Single-mode fiber |
1000 Mbps |
10 km |
GLC-BX-U= |
Single-mode fiber |
1000 Mbps |
10 km |
SFP-H10GB-CU1M= |
Copper coax |
10 Gbps |
1 m |
SFP-H10GB-CU3M= |
Copper coax |
10 Gbps |
3 m |
SFP-H10GB-CU5M= |
Copper coax |
10 Gbps |
5 m |
SFP-10G-SR= |
Multimode fiber |
10 Gbps |
26 m to 400 m |
SFP-10G-LR= |
Single-mode fiber |
10 Gbps |
10 km |
SFP-10G-SR-S= |
Multimode fiber |
10 Gbps |
26 m to 400 m |
SFP-10G-LR-S= |
Single-mode fiber |
10 Gbps |
10 km |
10-14-2020 12:58 AM
Hi Martin,
if i understand correctly i can use these cables and these tansceivers. the switches will be either above or beside
this cable:
I therefore need the fiber cable I think. it must be at least 26 meters long, did I understand correctly? if so it is convenient to have the switches nearby
Thank you very much
10-14-2020 01:22 AM
Hi there,
Martin
