09-21-2022 01:29 PM
I purchased a CBS350 switch I have 3 VLAN setup and they are trunked and have no problem talking to each other. When I add a pc to it and ping it from SSH, intermittently between 10 -15 pings I get a 4-20MS latency time. The PC is the ONLY thing on the switch and it is not on the network. Is this a defective switch?
09-21-2022 03:56 PM
what firmware it running, if possible upgrade to the latest firmware, reset to factory and recreate the test and let us know.
09-22-2022 04:43 AM
Thanks for the quick response. Upon opening the box I immediately upgraded it to 3.2.0.84. After that, I have factory reset a few times due to some general testing of some configs we wanted to try. As of now I have it setup and it works PERFECT as far as trunking, 3 VLAN talking to each other and DHCP distribution, but the latency in the ping has me COMPLETELY confused as nothing else is on the switch except the one PC.
Thanks again!!
09-22-2022 05:03 AM
i would try adding another device and test it...so we are sure the outcome same as PC.
09-22-2022 05:07 AM
Unfortunately I have. To test my config i added a few unmanaged and managed L2 switches just to test to make sure my config worked with our current environment (we're a small company) and pinging through those switches, the IP on the managed L2 switch as well as a laptop attached to those L2 switches produced the same latency. Fortunately it wasn't increased latency but the same type of latency I was receiving with just the PC attached to it.
