10-13-2024 04:40 AM
How can I do my cisco 250 unmanaged?
(Cisco Business 250 Series 250-48T-4G Switch 4)
I have an issue to test.
a software program, can't go trough the switch out, it blocks? If bypassing the switch direct to the router it works.
10-13-2024 06:02 AM
You dont need to make the device unmanaged. Unmanaged meains you can not access the switch to change the config. If you are connecting the CBS250 to a router, you need to prepare both devices to co-exist.
The simple way to work with this scnario is access the switch and make sure all the interfaces you are using is on the same vlan.
https://www.youtube.com/watch?v=hzwnXYw4Tss
10-13-2024 06:52 AM
Thanks Flavio, I'll try
Tom
