11-25-2019 04:29 AM
Hi All,
I have configured cisco SG350, everything works fine, but I have a problem with remote access to this device from different vlan, from vlan where is configured sw sg350 I can access via http,https, ssh and I can also ping device, but from different VLAN I cannot even ping to SW.
Do you have any idea, what is a issue ?
Thanks in advance
11-25-2019 02:32 PM
Hello Jaro
You have to enable VLAN Interface State -> Enabled (under VLAN Managment) and then assign IP (under IP Configuration).
Best regards
adam
11-26-2019 10:45 PM - edited 11-26-2019 10:51 PM
Vlan interface status was enabled....I do not have problem with access from same network as cisco SG350 is configured, I have a problem to access to cisco SG350 from different network (it is not problem of FW, allowed any any), I cannot either ping SW.
Thank you
11-27-2019 03:56 AM
Hi Jaro,
Please check the following settings…
11-27-2019 11:48 PM
Finnaly I found a solution, switch is configured as L2, without L3 routing.
I forgot basic thing, to add ip default gw.
Now it works.
11-28-2019 04:34 AM - edited 11-28-2019 04:34 AM
Hi Jaro,
Good to know that the issue has been resolve now.
