SG200-8 802.1x fails
Boris Bahes
Hi!
I'm testing new switch sg200-08 (firmware: SG200-08x_FW_1.0.6.2.stk) for 802.1x with RADIUS authentication.
For RADIUS server I use Microsoft 2012 NPS. For client I use Windows 7.
So far I have been unable to authenticate to RADIUS. So maybe I'm doing something wrong...
First thing I noticed is that documentation (200 Series 8-port Smart Switches Administration Guide - Page 136) says:
Key String—A shared secret text string used for authenticating and
encrypting all RADIUS communications between the switch and the RADIUS
server. This secret must match the secret configured on the RADIUS server.
The secret key can be edited by deleting the entry and recreating the entry
with the desired secret key. This must be an ASCII alphanumeric value
between 32 to 176 characters.
Now this is a problem (I guess)...since in interface of switch I can't enter value larger that 16 characters....
On the switch log I allways get this message when I try authenticate with Windows 7 client:
85 2013-04-23  07:59:31 Notice DOT1X[dot1xTask] dot1x_radius.c(246)  951 %% Failed to  authenticate on lIntIfNum [32] - Radius Request Timed Out.
84 2013-04-23  07:59:31 Notice DOT1X[dot1xTask] dot1x_sm.c(1277)  950 %%  dot1xBamMachine Dot1x authentication failed on intf 3, for user 'bbahes'.
On the server side I get three same messages in Security log:
Log Name:      Security
Source:        Microsoft-Windows-Security-Auditing
Date:          23.4.2013. 7:56:42
Event ID:      6274
Task Category: Network Policy Server
Level:         Information
Keywords:      Audit Failure
User:          N/A
Computer:      KLSERVER
Description:
Network Policy Server discarded the request for a user.
Contact the Network Policy Server administrator for more information.
User:
Security ID:                              NULL SID
Account Name:                              bbahes
Account Domain:                              -
Fully Qualified Account Name:          -
Client Machine:
Account Name:                              -
OS-Version:                              -
Called Station Identifier:                    84-78-ac-a5-83-11
Calling Station Identifier:                    d4:3d:7e:57:f5:4f
NAS:
NAS IPv4 Address:                    192.168.125.54
NAS IPv6 Address:                    -
NAS Identifier:                              84-78-ac-a5-83-10
NAS Port-Type:                              Ethernet
NAS Port:                              3
RADIUS Client:
Client Friendly Name:                    NEXUS3
Client IP Address:                              192.168.125.54
Authentication Details:
Connection Request Policy Name:          Secure Wired (Ethernet) Connections
Network Policy Name:                    -
Authentication Provider:                    Windows
Authentication Server:                    KLSERVER
Authentication Type:                    -
EAP Type:                              -
Account Session Identifier:                    -
Reason Code:                              96
Reason:                                        Authentication failed due to an EAP session timeout; the EAP session with the access client was incomplete.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-Security-Auditing" Guid="{54849625-5478-4994-A5BA-3E3B0328C30D}" />
    <EventID>6274</EventID>
    <Version>0</Version>
    <Level>0</Level>
    <Task>12552</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8010000000000000</Keywords>
    <TimeCreated SystemTime="2013-04-23T05:56:42.268504600Z" />
    <EventRecordID>1012</EventRecordID>
    <Correlation />
    <Execution ProcessID="528" ThreadID="2720" />
    <Channel>Security</Channel>
    <Computer>KLSERVER</Computer>
    <Security />
  </System>
  <EventData>
    <Data Name="SubjectUserSid">S-1-0-0</Data>
    <Data Name="SubjectUserName">bbahes</Data>
    <Data Name="SubjectDomainName">-</Data>
    <Data Name="FullyQualifiedSubjectUserName">-</Data>
    <Data Name="SubjectMachineSID">S-1-0-0</Data>
    <Data Name="SubjectMachineName">-</Data>
    <Data Name="FullyQualifiedSubjectMachineName">-</Data>
    <Data Name="MachineInventory">-</Data>
    <Data Name="CalledStationID">84-78-ac-a5-83-11</Data>
    <Data Name="CallingStationID">d4:3d:7e:57:f5:4f</Data>
    <Data Name="NASIPv4Address">192.168.125.54</Data>
    <Data Name="NASIPv6Address">-</Data>
    <Data Name="NASIdentifier">84-78-ac-a5-83-10</Data>
    <Data Name="NASPortType">Ethernet</Data>
    <Data Name="NASPort">3</Data>
    <Data Name="ClientName">NEXUS3</Data>
    <Data Name="ClientIPAddress">192.168.125.54</Data>
    <Data Name="ProxyPolicyName">Secure Wired (Ethernet) Connections</Data>
    <Data Name="NetworkPolicyName">-</Data>
    <Data Name="AuthenticationProvider">Windows</Data>
    <Data Name="AuthenticationServer">KLSERVER</Data>
    <Data Name="AuthenticationType">-</Data>
    <Data Name="EAPType">-</Data>
    <Data Name="AccountSessionIdentifier">-</Data>
    <Data Name="ReasonCode">96</Data>
    <Data Name="Reason">Authentication failed due to an EAP session timeout; the EAP session with the access client was incomplete.</Data>
  </EventData>
</Event>
The switch is in default configuration, so no VLAN's are used.
I called support and they told me it has to be something with virtual machine (since I'm using NPS on 2012 Hyper-V). But I also used Oracle Virtualbox and VMware and results where same.
In attachment is Wireshark capture of radius requests.
Thanks for any help!
Best regards,
Boris Bahes.
Tom Watts
Hi Boris, what syntax does the RADIUS expect for the mac address?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I haven't changed too much default Windows Server 2012 NPS settings. Most are default. I ran Configure 802.1x wizard in NPS console. But here is configuration in XML file so you can check. Also in attachment is switch running configuration.
PS. I have downgraded firmware to 1.0.5.1 and problem is still there.
Problem was solved by connecting client and NPS server to domain controller. My guess is that was certificate distribution related issue.
