SG300-28 Forgot Password
Blue Demon
i have a SG300-28 switch here but I do not have the password to login the device. From the startup config of the switch, I see the login password is encrypted. Are there anyway for me to access the device without reset it?
Tom Watts
Hi Blue, yes there is a password bypass procedure.
You will require console access.
Follow the first part of this document
https://supportforums.cisco.com/docs/DOC-27000
Step 1, 2 and 3 and notice on step 4, instead of option 1, use option 3.
After this, the switch will boot up normally then you should just be able to hit enter to get pass the password.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
8 Replies 8
Tom Watts
-Tom
Hi Tom,
Thanks for the guide. Now I can login to the switch already.
manzeel
hello tom can you give access to this document..for password recovery.
Yeah, even though I'm logged in, I get "You are not authorized to access this page".
Manjil - I have to do the same procedure. From what I've read, connect via serial, you have to restart your switch, then there is a bypass password option during boot. This will get you into the switch; which gives you access to change the password, and then save it. Reboot again. Then you should be able to log in with the new password.
But yeah, I'm frustrate when you find someone that lists a solution - linking to another page, or document, but can't get to the document.
Thanks, Whoward01 for your response
nilamani_nm
Hi Tom,
I'm trying to access the url but this is not being accessible to me and prompting that;  you are not authorized, can you please forward the document to me on "technoworld.nm@hotmail.com".
With Regards
Nilamani Sahoo
hkakarla1
Could you please provide access to this document. I am running into this issue.
After the boot, I do not see the options. Your help is appreciated.
nilamani_nm
Still I'm unable to access the document through given url.
