05-27-2014 05:01 AM
hello,
we want to change the password of our switch but we doesn't know it. We can access phisically to the console but it asked user and password??
We have read you can launch the recovery-password service from boot menu. But , how we can get to the boot menu without the password?
best regards
Solved! Go to Solution.
05-27-2014 03:47 PM
In order to reset the password from the boot menu you need to interrupt the boot process of the switch. Console in and power cycle the switch, you should see the Cisco logo, then you have about two seconds to hit a key to get the boot menu. If you miss it (or it times out once your in it) just power cycle the switch again to bring it up again. On the switch in front of me it is option 3 to reset the password.
However it is possible to disabled this option, so if it is not available even in the boot menu the only way to regain access to the switch will be to factory default it by holding down the rest button for 30 seconds. You will then have to reconfigure the device, but the default login of cisco/cisco will get you in once the switch resets.
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
05-27-2014 03:47 PM
03-08-2017 10:36 AM
For some of us, it's important to be aware that once the password is entered (or other changes made and saved) that you need to get out of the menu into the CLI and enter this:
copy running-config startup-config
Without doing this, it's going to revert when it's rebooted.
RIght?
06-02-2014 07:32 AM
hello Christopher,
it worked.
best regards.
09-16-2016 10:41 AM
Hello
Please share the document with me please i'm unable to change password.
Nilesh S.
+919764153299
nilesh.shedge@gsgtelco.com
