sg350 reboot loop
RoySargent7345
We have an SG350 that will not recover from this loop on boot. Tried to restore factory defaults but no success.  What are our options?
***** FATAL ERROR *****
Reporting Task: HCPT.
Software Version: 2.3.5.63 (date Aug 20 2017 time 19:03:04)
ros(HOSTG_fatal_error+0x14) [0x2a8b78]
ros(OSSYSG_fatal_error+0x134) [0x8226d8]
ros() [0x64248c]
ros(HALP_config_poe_692xx_dev_op_set_periodic+0xaec) [0xb6584c]
ros() [0xb57638]
ros(HALP_config_poe_691xx_692xx_poe_dev_operation+0x3c) [0xb57718]
ros(HALC_config_poe_dev_operation+0x44) [0xb69cf8]
ros() [0xb09bb8]
ros(HALC_config_device_dispatch+0x1a0) [0xb0ad08]
ros() [0xb24b3c]
ros() [0xb24d50]
ros() [0xb24dbc]
/lib/libp2linux.so.1(+0x3aa4) [0xb6f43aa4]
/lib/libpthread.so.0(+0x6e64) [0xb6f1ee64]
***** END OF FATAL ERROR *****
***************** SYSTEM RESET *****************
9 Replies 9
Sujoy Paria
We may need to process the replacement for the mentioned switch. Please open a service request with us following the below mentioned link to assist you regarding this issue…
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
RoySargent7345
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<!-- P {margin-top:0;margin-bottom:0;} -->
Sujoy,
Thank you for your response! Is this related to the Bug that I saw concerning the POE because we unfortunately have a total of 7 switches now showing the same symptoms.  Should I include these in this service request?
Hi Roy,
Thank you for your reply. You have not mentioned the bug ID so I’m not sure which bug ID you are referring. Please include the other serial numbers as well in case you are getting the similar logs on those switches.
Hello Sujoy,
The Bug is
Sx350/550 -HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: ...
CSCvk62334
The switches are
PSZ22101LYZ
PSZ22271HVL
PSZ22271J22
PSZ22271HUH
PSZ22101M0Q
PSZ21411CCJ
Hi Roy,
Please open a service request following the below mentioned link so that we can assist you regarding this issue…
SmokWawelski
Hi! I have the same problem. I bough that device on online auction, ant it supposed to be ok, but it is not.
Is there any solution to do this on my own?
Here is complete log:
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
Restarting system.
BootROM 1.41
Booting from NAND flash
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
PEX: pexIdx 0, detected no link
DDR3 Training Sequence - Ver TIP-1.56.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
Updated Physical Mem size is from 0x20000000 to 10000000
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
ROS Booton: May 31 2018 02:38:54
Press x to choose XMODEM...
Running UBOOT...
U-Boot 2013.01 (May 31 2018 - 02:38:39) Marvell version: 2014_T3.0_eng_dropv6 2.4.62
Loading system/images/active-image ...
secure boot not supported
Uncompressing Linux... done, booting the kernel.
I2C bus frequency: 100 kHz
ln: console: File exists
Thu May 31 02:36:00 UTC 2018
Linux MARVELL_LINUX 3.10.70 #2 SMP Thu May 31 02:39:45 IDT 2018
BOOTP_fs_init_ubi: Starting Boot...
MAC address : XX:XX:XX:XX:XX:XX. (MAC changed by me)
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
*** Running SW Ver. 2.4.0.94 Date May 31 2018 Time 02:37:28 ***
HW version is V04
Serial Number is PSZ23081BGE
Base Mac address is: 00:fd:22:47:3a:a0
Dram size is : 512M bytes
Flash size is: 256M
31-May-2018 02:36:07 %CDB-I-LOADCONFIG: Loading running configuration.
31-May-2018 02:36:07 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG350-10MP
Device 0: GT_98DX3233 (AlleyCat3)
CPLD version is: 0x0e
-- Unit Number 1 --
31-May-2018 02:36:15 %INIT-I-InitCompleted: Initialization task is completed
>31-May-2018 02:36:15 %PNPAGENT-I-AGENTREADY: PnP is ready
-- Unit Number 1 Master Enabled --
31-May-2018 02:36:20 %Environment-W-RPS-STAT-MSG: Power supply source changed to Main Power Supply.
31-May-2018 02:36:23 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
31-May-2018 02:36:23 %MLDP-I-MASTER: Switching to the Master Mode.
31-May-2018 02:36:26 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
31-May-2018 02:36:26 %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 0
31-May-2018 02:36:26 %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 0
The SSH Server is generating a default RSA key.
This may take a few minutes, depending on the key size.
The SSH Server is generating a default DSA key.
31-May-2018 02:36:29 %HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: HALP_config_poe_number_of_poe_devices is Zero: Failed on init.
Software Version: 2.4.0.94 (date May 31 2018 time 02:37:28)
last operation executed HALG_config_device_op_id_get_cpu_rx_counter_E (null) 1281
ros(HOSTG_fatal_error+0x14) [0x2e62a4]
ros(OSSYSG_fatal_error+0x134) [0x8752ec]
ros() [0x693ec0]
ros(HALP_config_poe_692xx_dev_op_set_periodic+0xa50) [0xc02c8c]
ros() [0xbf3ee8]
ros(HALP_config_poe_691xx_692xx_poe_dev_operation+0x3c) [0xbf3fc8]
ros(HALC_config_poe_dev_operation+0x44) [0xc06b30]
ros() [0xba4e80]
ros(HALC_config_device_dispatch+0x1a8) [0xba5fe4]
ros() [0xbc0884]
ros() [0xbc0a94]
ros() [0xbc0b1c]
/lib/libp2linux.so.1(+0x3aa4) [0xb6ed5aa4]
/lib/libpthread.so.0(+0x6e64) [0xb6eb0e64]
Had to RMA switches
Could you help me, what was the solution to your problem. I have the same inconvenience
Only solution was to contact Cisco and replace switches.
After I told them what was the problem, they have send new switch. When the courier arrived I had to give back my old switch.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
