SG350X 1GE SFP modul in 10GE SFP+ slot
jkon
We consider buying SG350X-48P switch, but we currently need 1GE uplink. Is there possible to use 1GE SFP module in 10GE SFP+ slot?
Sujoy Paria
You may try Cisco MGBSX1 / MGBLX1 / MGBLH1 modules, those are compatible as per the data sheet and quick start guide, please check the following links…
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html (Supported SFP / SFP+ modules section)
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xseries/quick_start/guide/350xseries_trilingual_qsg.pdf (Page 12)
Sujoy Paria
